I've just bought a 2 din Alpine head to replace the O/E 2 din head, so as to be able to connect my iPod for travelling music. Stereo fitter said he won't do it because after market 2 din heads don't fit in the facia because of the curve.
Does this sound right and if so, does anyone have a work around, bearing in mind I am up north not in a big city. Cheers Vincenzo
$DO || ! $DO : try try: command not found - (YODA the Geek) "WRC is for boys, Group B was for men" - Juha Kankkunen 4 times World Rally Champion Romanes Eunt Domus - 'people called Romanes they go the house' - You mean Romani Ite Domum [SIGPIC][/SIGPIC] |
Just cruisin'
Anything can fit. They tend to stick out a bit at the bottom, and don't look quite as good as they would if the dash was straight.
I have double din Screens in both my AU Lane, and my missus' AU Ghia...I installed the one in her car, it sits well. The one in mine came in the car, and it sits out way further at the bottom due to how it was installed. The thing is, hers basically angles down at the console due to being more flush with the dash, this is not an issue with a screen, because it folds out, and can be adjusted to whatever angle we like. If you have a non screen double din unit, if you mounted it flush with the dash, it would always aim downwards. So you will have to have it sitting out at the bottom a bit. I can take pics later today if you would like? |
#3 | |||
![]() Cheers Vincenzo
Just cruisin'
This is the unit in my Fairlane
It is probably more relevant to you anyway, because this is how yours will most likely need to sit. ![]() ![]() ![]() ![]() |
Defender of the faith
My local installer suggested when I enquired that he would go further back at the top so as to align the bottom. Not sure how that would affect viewing the screen though
Just cruisin'
#7 | |||||
If it's flush at the bottom it won't fit inside because the rear will be touching the top of the inside area - correct? Quote:
I will wait a day or two and see if anyone else maybe has an answer to this problem, if not damn the looks and I will just get it done. I actually didn't buy a 2 din for the screen, merely to fill in the hole in the dash. Cheers Vincenzo
Just cruisin'
Well its not really a problem in my eyes...Just it will either have to sit out at the bottom, or in at the top.
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
The other option of course is a single din with an aeropro pocket underneath.
Like this http://www.aerpro.com/list.php?pcode...KETS+&cat_sno= Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
T-Series Club Member Vic
My unit sits in a little at the top and out a little at the bottom. I'll go take a pic...
The mounting position...
![]() And the view from the driver's angle. ![]() |
#12 | ||
Rob
just chuck it in, it wont look that out of place. My double din kenwood headunit looks fine. Stress less.
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
Just cruisin'
#14 | ||
Well, I decided to change to a single din head unit so I got the Aerpro in black, and bought the wiring harness to retain steering wheel control use. I will attempt to fit this over the weekend.
Most of you might be saying so, whats the big deal. Well, if all goes well this is simply all plug and play with no programming needed. Add to that I will attempt to do it all myself, may the Gods of Ford look down favourably upon me. Will put up pictures if anyone is interested once it is done. Cheers Vincenzo
#15 | ||
Well, I couldn't wait for the weekend so I went and found a shady spot to have a go at doing this. Let's just say the Gods of Ford were off having lunch at the time.
To summarise, bought a 2 din head to replace the OEM head so I could attach my iPod Nano for music. 2 installers both said they would not install a 2 din head because it looks crap. Spoke with retailer and swapped 2 din for 1 din head and got Aerpro facia to fit, also got Aerpro cables to retain steering wheel controls (swc). I got everything together except I couldn't find where the (swc) plugged into the head unit. Spoke with mobile installer, he had a few spare minutes and came around and had a look. Single din head does not have input for (swc) but does have remote control. I had wired everything correctly prior to installing. He cleaned up a bit of the wiring, installed the bluetooth mic, paired the phone and head and did the final install. It wasn't worth the hassle of going back to the retailer for another head unit as the new one did come with a remote. So, if you want to keep your (swc), check and make sure the unit has the appropriate port on the back of the head. Aerpro have done a good job of making things easy for a change over, even I could get it right. I have pictures if anyone is interested, just let me know and I will upload. cheers Vincenzo
#16 | ||
5.6L x 2 pilot
You know the rules!
![]() Photos or it never happened! Stu
#17 | ||
OEM 2 din unit with removal tools
![]() Original Ford OEM cable and Aerial wire ![]() New head with Aerpro Alpine and Ford ISO cable attached. ![]() New head fitted and in dash ![]() Seeing the photo reminds me I have to remove the old mobile phone holder. Photos aren't that good as I had the shakes bad today - but I tried. Cheers Vincenzo
