Old 13-12-2012, 11:42 PM   #1
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default AU clock spring
Evening all, does anyone know if the clock spring is the same part right through from S1 to S3? The missus' wagon clock spring has died and I can get a S1 clock spring cheap but I need to know if it's ok to fit for S2?
Bushbasher
MINE- AUII Forte
Old 16-12-2012, 11:57 AM   #2
phr33k
Default Re: AU clock spring
they should all fit, the only thing to consider for you is if they all have the same wiring, say a stock s1 forte, im not sure if it would include the cruise and radio control wiring, the lanes have 6 wires to and from the clock spring, so as long as its got the right number of wires you'll be fine.
from what i have seen, they all have 6, they just aren't used in the lower models.
hope this helps
phr33k is offline   Reply With Quote Multi-Quote with this Post
