Hey all, I recently changed the rear rotors on my AU Lane and the end of one of the screws was rounded so I used a red lictight stuff to make sure it stayed tight... well problem now is that the handbrake needs adjusting desperately but I now can't remove it! Please help!
Auto Nerd
Remove the rubber grommet from the rotor and you can line it up with the hand brake adjuster to adjust the handbrake.
You'll need a propane torch and impact driver to get that screw out in future. |
RIP...
An impact driver should do on it's own.
. Oval Everywhere... |
where do u get the lock screws from?
how much does an impact driver cost roughly? |
RIP...
Don't worry too much about the screw, they're not really needed, the wheel/nuts hold the whole assembly together.
Just get a cheap impact driver, it'll do the job fine, maybe $20.
#7 | ||||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Ford still sell the screws,cost bugger all, i agree on the antiseize and they only need to be nipped up not super tight as already mentioned.
G'day.. local mechanic ended up drilling out the screws..so i'll have to get a new set... just to be sure i turn the handbrake adjuster clockwise to tighten?
