12-10-2012, 08:57 PM | #1 | ||
Just picked up some 5 slot jelly beans to fit to my ZH, the rears fit fine however the front studs barely make it past the lip of the holes on the rim to get the wheel nut on. They're just standard nuts, not tapered or anything. Has anyone had a similar issue or know how to overcome this? I'm pretty desperate as I need them on for a RWC ASAP!
12-10-2012, 09:03 PM | #2 | ||
HUGE MEMBER
Long shank wheel nuts bud. Bob Jane ect will order them in for you
I would not pee on a Holden if it were on fire. I would take pics and post for your pleasure My cruiser. 1979 Zh Marquis. "T" code 351. My garage queen :(. 1980 TF Cortina Ghia Wagon. 4.1. My dog. 2011 Sierra My Daily. 2012 ZH (lol) OUTLANDER xls. 4WD CVT. Sapphire blue Wanted Borg Warner Lsd or centre. 25 spline |
12-10-2012, 09:06 PM | #3 | ||
XD Sundowner
getting in first DO NOT DRIVE IT with normal wheel nuts , besides destroying your rims , they will snap wheel studs ...take your standard nut and rim to a tyre dealer they will give you the correct nuts
something old something blue |
12-10-2012, 09:11 PM | #4 | ||
****. So i'm in for a big job then. Any reason why the rears fit but the front dont?
12-10-2012, 09:14 PM | #5 | |||
Experienced Member
12-10-2012, 09:26 PM | #6 | ||
XD Sundowner
the wheel stud should barely stick out and the wheel nut goes through the wheel as a firm fit , was going to add a pic.. but i think you will get the idea , look at the rim just sitting on car and see the gap around wheel studs ... that is filled with the correct wheel nut with a sleeve looking bit on it as part of the nut , google wheel nut images and you will see the difference between tapered nut and alloy wheel nut ..
12-10-2012, 09:33 PM | #7 | |||
12-10-2012, 10:05 PM | #8 | |||
XD Sundowner
12-10-2012, 10:17 PM | #9 | ||
i'll check it out tomorrow, cheers!
12-10-2012, 10:36 PM | #10 | ||
13-10-2012, 10:38 AM | #11 | ||
I've got dragways on the EF and i found i needed 2 washers.
Previous Rides,'78' TE 6cyl Cortina,'90' TX3 Turbo 4WD Laser, '89' Honda 250CBR RR, '79' ZJ Fairlaine 351c, '69' XW Ute worked 250 pre-crossflow, '96' EF Gli, EA and EBII wagons. Current rides, '02' BA XT work ute, '96' EF Gli-AU head and cam, king springs, Custom Bodykit 2.5"+ Extractors (and its even got cruise control). |
13-10-2012, 11:13 AM | #12 | |||
I am Groot
Sounds to me like someone has been dicking around with the car sometime in it's past. Take it down to your nearest wheel and tyre joint, if they are good enough they should be able to put you on the right track.....
.. McLaren F1 Dick Johnson Racing "Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe Last edited by DJR-351; 13-10-2012 at 11:24 AM. |
13-10-2012, 10:30 PM | #13 | ||
Fixing Ford's **** ups
Different manufacturer of the rims? Jelly beans were made by 2 or 3 different companies, therefore they would have a different thickness centre of the rim. (They varied slightly in looks)
Do you have different width rims, front to rear? Might explain a few things too.. Providing you have wheel nuts like JIMSTONE posted up, they are fine to fit. They don't have to have the stud poking out....Just the right sort of wheel nut... Oh and when you put the wheel nut on, make sure they do up tight, and don't have a gap between the washer and rim face, otherwise you may have to put an extra washer on the ones that are loose (as ADO351C mentioned)
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
14-10-2012, 12:11 AM | #14 | ||
playing in my big shed
could possibly have had longer wheel studs fitted to the rear axles.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch `10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim. `04 BA RTV tray back, Red, V8 auto, `04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim. `03 BA XLS ute . Acid Rush, factory lpg, auto, `48 TEA20 Grey Ferguson, `62 Willys 6-230 , 4x4 light truck `04 Yamaha TTR 250 |
14-10-2012, 12:20 AM | #15 | |||
Make sure the centre bore diameter of the front rims is large enough to sleeve over the raised boss in the centre of your front hubs (ford 70.6mm) Just incase they have been fitted to a Toyota at some stage check to make sure someone hasn't left some hub adapter rings in place too (Toyota 67.2mm) |
14-10-2012, 08:02 AM | #16 | |||
Money Talks, but all i ever hear is it saying Goodbye!! |
14-10-2012, 09:15 AM | #17 | ||
Be careful as mentioned earlier there was a change in front hub size from XB to XC,
some early mag designs have the early smaller hub centres and don't quite seat home on the spiggot. If this is the problem, putting longer studs on could be very dangerous.... |
15-10-2012, 04:31 PM | #18 | ||
The Jellybeans I have require a straight mag wheel nut and washer, not a tapered nut at all. You shouldn't need longer studs if you have the correct nut for those wheels.
15-10-2012, 06:28 PM | #19 | ||
they arent Valiant alloy jelly beans by any chance?
they use a tapered style wheel nut, that fits inside the alloy rim too. can you post up some pictures of the rims you are trying to fit?
15-10-2012, 06:39 PM | #20 | ||
All sorted! Used some long shank wheel nuts (after I finally tracked some down)
15-10-2012, 06:41 PM | #21 | |||
It's an extremely important to get this right though. Could be that the rear diff was replace with an earlier small center one and the OP's jellys are small center. |
15-10-2012, 07:07 PM | #22 | ||
it's all sorted, i just swapped them - i had taken 2 of the wrong ones from mu pal when i bought them. 2 off a ford & 2 off a valiant.
Thanks for all the help and input guys, i really appreciate it. |
