Old 27-09-2012, 03:17 PM   #1
tickford6
Default How can you fix and reenforce bent pedal box ??
Hey guys just wondering how to fix and straighten up a bent clutch pedal box and reenforce it ? Any help will be appreciated thanks
tickford6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2012, 04:03 PM   #2
Kieron
Default Re: How can you fix and reenforce bent pedal box ??
Would this be an E series Falcon by any chance?
If so, and going by memory there is a triangular plate that is spot welded onto the main pedal box assembly that breaks at the spot welds. I simply had holes drilled thru the two plates and sandwiched them back together with nuts and bolts.
Kieron is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2012, 04:47 PM   #3
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
I had a Bent Pedal Box on ProEF
Welded some thick metal at the pivot point - not pretty but effective
But had to remove remove dash to get to it - have fun with that :(
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2012, 08:54 PM   #4
mik
mik's Avatar
that`s looks to be a stout repair Sorted, no mucking around here, well done, you can repair my kenworth chassis rails any day ;).
Old 27-09-2012, 08:57 PM   #5
ebxr8240
Performance moderator
ebxr8240's Avatar
Repairing the Keny would be easier !!!
Daily driver GTE FG..
Old 27-09-2012, 09:07 PM   #6
Coyote mk3
Clutch Cable Killer
Coyote mk3's Avatar
I pretty much did the same as Sorted, although slightly smaller piece of metal welded on
But going strong so far. It's been there for over 6 months now.
Enjoy taking the dash out. And whatever you do don't crush any wires when bolting the pedal box back in...you may have difficulties starting the car if you crush the right ones hahaha
Matthew
1997 Manual EL XR6 in Heritage Green
Coyote's EL XR6
^^Click Me^^
Coyote mk3 is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2012, 09:13 PM   #7
mik
mik's Avatar
indeed it would .
Old 27-09-2012, 09:20 PM   #8
XR Martin
XR Martin's Avatar
Dont know what's the big deal in pulling the dash, its all pretty straight forward. Just time consuming.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 27-09-2012, 09:45 PM   #9
tickford6
It's au xr6, is it the same pedal box as the e series ? I don't think I'll have to take the dash out will I?
Old 27-09-2012, 10:20 PM   #10
mik
mik's Avatar
it`s a bit back breaking if your an old fart :(
Old 27-09-2012, 10:46 PM   #11
au adam
au adam's Avatar
Just get a new one and reinforce that.While you at it replace the clutch cable.
au adam is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2012, 12:26 AM   #12
Kieron
Welding you will have to take the dash out, the bolt method I had done can be done with the dash in (this was on an EF) using a flexible drill shaft then large nut/bolt with locking washers, worked perfect and never had a problem with the HD clutch/pressure plate I had in it.
Old 28-09-2012, 07:29 AM   #13
Nikked
Oo\===/oO
Nikked's Avatar
Elaborate more....
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2012, 07:57 AM   #14
tickford6
I'm liking the bolt method haha, can you explain it a bit more ? Thanks
Old 28-09-2012, 08:06 AM   #15
tickford6
Are you sure have to take the dash out? It's an au, I got under it then and you can get to every bolt it's just going to need some skilled mongering to get around the sterring Collum but should be revatibly easy?
Old 28-09-2012, 11:13 AM   #16
graham7773
I agree with AU Adam (has anybody priced a new pedal box from Ford?) but Ford aus simply did not learn. This problem went on for 10 years. All the E series had it and it can be a beartch to fix as sometimes the firewall tears as well as the pedal box bending and cracking. I have to say that in my EB I didn't remove the dash but I was a bit more flexible then. I plated the firewall, strengthened the pedal box and replaced the clutch cable....then sold the car. I will never trust another E series manual. Seen too many fail.
graham7773 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2012, 12:30 PM   #17
Sorted
Sorted's Avatar
If you look at the pedal box you will see that attaching a clutch pedal to the side of it seems like an after thought and not well nutted out.
The Brake Pedal and the Accel Pedal are supported on both sides by the pedal box's frame BUT the clutch pedal is just attached with what is basically a bolt on one side of the pedal box's frame - it has no support for the other side of the bolt - this is why it bends the pedal box frame
Mal Wood has the right idea with this Pedal Pin Kit - it has more than enough support for the pedal box to not bend - this can be fitted to an Auto Box and it's said you don't have to remove the dash to fit it
It was just a chunk of metal lying around - very dodgy repair but it does the job
indeed it would .
lol
After you fix the Pedal Box you may want to reinforce your fire wall as well as they tend to fail as well - these also have no support
[QUOTE=Sorted]Cam.
Of coruse the pedal moves as the cable is still attached to the clutch pedal
BUT that cable is supposed to be fixed to the fire wall as per below pics
yours has broken - common issue with the fire walls
How to make a fire wall plate http://www.fordmods.com/post848422.html
Clutch cable with Fire Wall Plate - see no cable is showing
[QUOTE]
Tuned by DYNOMOTIVE
Old 28-09-2012, 01:35 PM   #18
Kieron
It's been 10 years or so now, but from memory -
In Sorted's first pic, you can make out the additional clutch bracket that is spot welded in 3? positions to the main pedal box. In my case, one of these spot welds broke which, I believe is the usual problem.
As you can't get a full on drill up inside the dash, use a flexible drill shaft -
Drill the broken spot weld(s) out, you may have to drill a pilot hole then enlarge it with a bigger drill bit.
Get a large nut/bolt, some flat washers plus locking washers and bolt it all back up using a bit of muscle to clamp the bent bracket flush against the main pedal box.
In my case it was an EF and there was enough room to get the flexible drill up inside the dash, hopefully an AU has enough space to get it in too.
