Old 11-09-2012, 11:34 PM   #1
caputo9
Groundbreaker
caputo9's Avatar
Default PS3 Network Problem
Hi Guys,
I haven't been on here for a while and I'm not sure if this post is in the right section, if not please redirect me, otherwise can you please help me out.
Recently I purchased a new Belkin N600 DB N+ Modem/Router and have been having problems regarding connecting my PS3 to it.
I connect it through wireless and have set up a static IP Address for it through the DMZ setting in the router. it works and i can play online with it but on all games i play, it says i have restrictive Internet (NAT Type:Strict).
When i complete an internet test in network settings it says:
IP address: Successful
Internet Connection: Successful
Playstation Network Successful
UPnP: Unavailable????????????????
NAT Type: Type 2
The UPnP setting is what i believe is wrong but i don't know how to fix it.
I have gone through the router settings and it is Enabled and i dont know what to do.
Before i purchased the new router, the playstation would work fine and connect to everything easily but unfortunately that old router i was using died.
Could you please help me as i am very confused with the UPnP setting and i wonder if its the problem.
Thanks in advance.
03 VW GTi - Stage 2 Custom Code, 3" Stainless Turbo back, BC BR Coilovers, BMW X5 Wheels and much more
caputo9 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2012, 12:00 AM   #2
xa_boy
xa_boy's Avatar
Default Re: PS3 Network Problem
UPnP is considered to be: "Universal Plug and Play".
My guess is when you try to connect to the Internet with the PS3, it is saying that the UPnP isn't available? There is a possibility that your router doesn't support UPnP. What you would have to do is access your router and configure it to allow the IP Address for the PS3 to open and close ports as they need to
Ac Cobra DRB: 302 Windsor, Roush Snr. heads, edelbrock performer rpm, comp cams xe282hr, Yella Terra roller rocker, 750 Demon, Msd 6al. 405hp
xa_boy is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2012, 12:14 AM   #3
caputo9
Groundbreaker
caputo9's Avatar
I'm sure my router supports UPnP as it is located in router settings.
And I have configured my ps3 settings so that it only runs on one ip address every time I turn it on. (also known as static ip address)
Here's a link to the description of my router:
http://www.belkin.com/au/IWCatProduc...duct_Id=552270
Thanks
Old 12-09-2012, 12:44 AM   #4
creative
I am Batman
creative's Avatar
Have you tried it on ethernet?
Also try disabling upnp seeing as you are in dmz.
creative is offline   Reply With Quote Multi-Quote with this Post
