05-08-2012, 01:24 PM | #1 | ||
Just trying to undo some wheel nuts that were obviously put on way too tight by the ********* at Tyres Now...
Tried... wd-40, silicon spray, bar with my weight (broke the socket), impact gun... whats left?
Built & Tuned By... PITLANE AUTOMOTIVE - FRANKSTON VIC 03 9783 8122 |
05-08-2012, 01:27 PM | #2 | ||
bigger breaker bar and better socket , or bigger impact gun
05-08-2012, 01:58 PM | #3 | ||
Fixing Ford's **** ups
A breaker bar, with a decent branded socket and 1 big piece of pipe. Works a treat for me and I weight 90 kg ringing wet.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
05-08-2012, 01:59 PM | #4 | ||
breaker bar , impact socket, plenty of weetbix
11 second car with a 12 second driver Blown BA GT mk 2 manual in Envi |
05-08-2012, 02:08 PM | #5 | ||
Garage jack handle on breaker bar. The real trouble starts when the studs start spinning.
05-08-2012, 02:38 PM | #6 | ||
Where to next??
Wheel brace with a 6 foot length of pipe threaded on the end for leverage. A 4 way brace is much better as you can support the other end with a chassis stand to keep all the angles correct. At the end of a 6 foot pole a 6 year old will get those nuts off.
05-08-2012, 02:50 PM | #7 | ||
Thailand Specials
1/2" impact gun lol.
Always made me wonder when working at a dealership, you'd get taught as an apprentice to only use the impact gun to take wheels off, when doing them up set it on its lowest setting to hold the wheel there. Lower the car, then use a torque wrench and tighten to 110nm and she's good to go. But you see mechanics there with their 1/2" impact guns on its highest setting going BANG BANG BANG BANG BANG on every wheel nut, tightening them up to like 300nm+. Good luck for the poor person on the side of the road trying to change a wheel with that ****y little wheel wrench they give you. |
05-08-2012, 02:57 PM | #8 | ||
another vote for impact socket, breaker bar and bit of pipe.
05-08-2012, 03:00 PM | #9 | ||
Take the car back to where they tightened them and tell the peanut that put them on to undo them, if they break wheel studs or strip threads or damage wheel nuts you can get them to replace them then and there at their expense.
If you start leaning on it and break wheel studs, damage threads (which are probably damaged now anyway from over tightening the nuts) then it becomes your problem to repair at your own expense. Wheel nuts do not have to be that tight, and as a matter of fact should not be too tight.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave |
05-08-2012, 03:13 PM | #10 | |||
There's a better than average chance the thread on the studs are now stretched and will give you trouble down the track (coming loose or Possibly breaking etc) So go down tell them you can't get them off since they fitted them
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
05-08-2012, 03:16 PM | #11 | ||
even worse when the imbeciles do it to alloy wheels, I don't care how much longer it takes to do them up they are not using rattle guns on any alloys on my cars, and tension wrench to finish it off
03 BA XLS 6cyl Ute-Mercury Silver 04 Subaru Liberty GT Premium 99 Toyota 105 series Cruiser TD 99 5.8M Profish plate alloy carport decoration |
05-08-2012, 03:40 PM | #12 | ||
I use a rattle gun to do them back up but not to a tightness, just to save time on putting the bastards back on there!
05-08-2012, 04:28 PM | #13 | ||
got bigger piece of pipe... sore wrists... and they're off! thanks for all advice!!!
05-08-2012, 04:38 PM | #14 | |||
For what it's worth, my tyre blokes use a rattle gun to fit all wheels and then do the actual tighten by hand with a standard wheel brace.
05-08-2012, 04:54 PM | #15 | |||
Ford Fanatic
Everyone is entitled to my Opinion 2007 Territory TX SY RWD Ego |
05-08-2012, 04:55 PM | #16 | |||
05-08-2012, 05:56 PM | #17 | ||
Should try early Mopars .. LH threaded, LH side wheel nuts. Morons with rattle guns can do some real damage with those as they just keep pushing up the gun torque trying to undo them ...
05-08-2012, 06:09 PM | #18 | |||
Yes there are rattle guns that can do this, if they are kept in good condition, I have seen the way some tyre fitters throw them around, I wouldn't trust the torque setting to be right
05-08-2012, 07:45 PM | #19 | |||
05-08-2012, 07:46 PM | #20 | ||
R51 Pathy, 91 Jayco Swan
Getting new rims again Worm?
05-08-2012, 07:50 PM | #21 | ||
Put anti seize on the studs when you fit new ones,wont happen again.
05-08-2012, 08:16 PM | #22 | ||
carefactor zero
The boys at Beaurepaires in Dandenong South use rattle gun till just tight then torque wrench.
05-08-2012, 08:44 PM | #23 | |||
05-08-2012, 09:17 PM | #24 | |||
Winter White Weapon
FG FVI XFT Enhanced 360rwk/806nm |
05-08-2012, 09:33 PM | #25 | |||
I use these where I work at the moment....Top stuff. other places, the most common thing used is a tension wrench.
06-08-2012, 10:58 AM | #26 | ||
Lefty loosey mate....lefty loosey
My Daily VT Wagon, stock. I hate Holdens, but the wagons look better than the Fords. Shame. Ma Project Car Now Grandpa ED with ma hectic louvres, LPG, stock as she goes, surprisingly reliable and goes ****in hard on gas! Toy Car XF UTE with XR6 Headlights, Chromed 12 Slotters, 4.1L 250 Crossflow, Triple Holley Carbs, Stage 4 Crow Cam, Extractors, 3" Exhaust, Yella Terra Roller Rockers, 5 Speed TREMEC Manual Box, 3.45 9" LSD. SOLD :( Come at me Holden. |
06-08-2012, 12:33 PM | #27 | |||
06-08-2012, 12:57 PM | #28 | ||
Stroking it...
Worm... This is your cars way of saying "Stop bloody changing wheels"
Had: 347ci AU Then: Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
07-08-2012, 03:25 PM | #29 | ||
"What's that wheel doing on your crotch?"
"Argh, it's drivin' me nuts!"
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
07-08-2012, 03:46 PM | #30 | ||
Broken
If they were that tight, think id be replacing the studs.
The Scud GT 11.4 @ 128, 1.88 60ft. |
