Peter Car
Super impressive revs and power for such a tiny engine. This is a Hybrid worth buying, if your mega rich.
-------------------------------------------------------------------------------- By MIKE COSTELLO JAGUAR has revealed that the plug-in hybrid drivetrain in its forthcoming C-X75 supercar will feature a remarkable F1-inspired 1.6-litre twin-charged four-cylinder petrol engine with around 375kW of power and a remarkable 10,000rpm redline when it hits the road within three years. The company previewed the new engine – reportedly developed in-house – to UK motoring media this week, ahead of the car’s limited 200-unit production run set for 2014. It is expected to be priced at around £900,000 ($A1.35 million). The turbocharged and supercharged engine will supplement an electric motor placed on the rear axle, either driving the rear wheels directly or charging the batteries. A fast-acting supercharger will provide boost at low revs, with the turbo kicking in further up the rev band. A separate electric motor located at the front will provide constant power flow to the front wheels via a separate transmission, giving the C-X75 all-wheel drive. It may not be quite as radical as the pair of lightweight gas turbines found on Jaguar’s original concept car from the 2010 Paris motor show, but the projected performance figures suggest the production car will be even faster. Jaguar told the British media that the powertrain has entered the working prototype stage, and is confident of a sub-3.0-second 0-100km/h sprint time and fuel consumption as low as 4.0 litres per 100km. By contrast, the original C-X75 concept’s powertrain – consisting of a 145kW/400Nm electric motor on each wheel and two gas turbines producing 70kW at a constant 80,000rpm – had a claimed sprint time of 3.4 seconds. Thanks to its large battery pack – said to be the heaviest component of the car at around 200kg – the production model is projected to have a pure electric range of 60km, and be able to dash to 100km/h in around 6.0 seconds on electric power alone. These figures would put the C-X75 in the same performance ballpark as Porsche’s forthcoming and equally expensive 918 plug-in hybrid, but unlike this car the Jaguar is confirmed for right-hand-drive production, allowing it to potentially grace Australian roads. According to Autocar, the mid-mounted engine will have both direct and port-fed fuel injection and will sit flush with the centrally located, liquid-cooled 600-volt battery pack. Power will be delivered to the rear wheels via a seven-speed automated manual transmission, rather than a heavier dual-clutch unit. As previously revealed, the car will feature extensive use of carbon-fibre, with the lightweight material used on the chassis, most body panels and the rear sub-frame. The overall structure is said to have been created in conjunction with the Williams Formula One team, with Jaguar said to enjoy direct access to the team’s facilities. It is also interesting to note that Formula One is set adopt 1600cc turbocharged engines in the near future, albeit of the six-cylinder variety. Autocar says the exterior design of the finished product will closely resemble Jaguar’s sleek and low-slung Paris concept. GoAuto reported in October last year that the company had received expressions of interest from two cashed-up Australian fans, and Jaguar Australia brand manager Kevin Goult today confirmed that this was still the case. “We still have people interested,” he said. “The two potential prospects are still around; they will be talked to.” Mr Goult said the limited run of 200 cars globally had “pretty much been snapped up”, meaning the two prospective buyers were likely to be the only Australians in with a shot of buying the car new. The upcoming Jaguar and Porsche might be just the start of a trend when its comes to hyper-power hybrid supercars, with Ferrari also reportedly developing a petrol-electric powertrain for an Enzo-replacing flagship. The Italian car-maker displayed an updated version of its hybrid kinetic energy recovery system (Hy-KERS), designed to fit around a V12 engine with a mid-rear installation, at the Beijing motor show in April. At the slightly more affordable (and tamer) end of the scale, BMW will put its long-awaited i8 plug-in supercar into production next year, with similar radical styling to the concept and a likely 0-100km/h sprint time of less than five seconds. |
Where to next??
Wow... wonder if that power figure is from the 1.6L engine alone, or combined with the electric motors??
Wonder what the servicing / lifespan of the engine is?
it sounds like it would be a fun drive!!! I wonder what it will sound like!!!
#4 | |||
Volvo were making very small displacement diesel engines for marine applications that were high pressure supercharged and turbocharged. Longevity was a major issue as was the failure rate which I understand was nearly 70% ![]() One method of forced induction is clearly more than enough. |
#5 | |||
No longer a Uni student..
![]() Thats why they are only building 200 of them.
Previous: 1992 Mitsubishi Lancer - Petrol/Manual/Silver 1997 Ford Falcon GLi - Petrol/Auto/White Current: 2012 Ford Focus Sport - Petrol/Manual/Black |
Render unto Caesar
project has been cancelled.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
Peter Car
Such a shame, I wanted to see what this little turbo/supercharged 1.6 could do. 10,000 rpm.
