Old 01-06-2012, 06:02 PM   #1
memnoch
memnoch's Avatar
Default K&N panel filter
hey guys i just bought a k&n panel filter for my BF F6, but they gave me a filter for a FG F6, its a little bit bigger but not by much,, the air box clips on,, just a bit tight,, is it still ok
BF F6 Typhoon
1 of 17 DeJa Vu build # 0499
running 15psi @321.7 RWKW
memnoch is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2012, 10:27 PM   #2
Windsor342ci
The Experience...
Windsor342ci's Avatar
Default Re: K&N panel filter
If the box still closes id imagine any possible gaps would now be clamped down. If you can return it go for it, if not I think it will be fine.
Her Daily: BF XR6T ZF
His Daily: FGX XR8 ZF
Their Pride: T3 TE50 Manual
Windsor342ci is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2012, 10:56 PM   #3
memnoch
memnoch's Avatar
i just spoke to Theo from bluepower he haid its fine,, i BF has square edges, can trim it a bit, but its fine, dont really want to return it, cause they were on special for 70,, otherwise, will have to pay 100 for the BF one lol
BF F6 Typhoon
Old 02-06-2012, 07:44 AM   #4
GTBenny
GTBenny's Avatar
The filters are different and personally I wouldn't fit the FG filter to a BF. This pic will show you the differences, might be small but was enough for me to buy the right one when I bought my turbo back in 2008.
Benny.
GT 335 MKII, ZF6, Tein coilovers, YT snout, 61mm pulley, KPM 1500HP fuel system, 1000cc injectors, E85, KPM exhaust, BMC air filter, KPM Streetfighter intercooler, built tail shaft, Truetrac, 479rwkw - 950nm.
GTBenny is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 01:06 PM   #5
EB#
EB#'s Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Constant helpful advice and step by step guides in easy to understand format with pictures.
Agree with above.
Take it back and get the correct part.
EB# is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 02:19 PM   #6
memnoch
memnoch's Avatar
i did
BF F6 Typhoon
Old 02-06-2012, 02:40 PM   #7
Shonky.
Shonky.'s Avatar
nice post Benny
(thank you, on behalf of OP)
Shonky. is offline   Reply With Quote Multi-Quote with this Post
