Closed Thread
Old 13-05-2012, 08:36 PM   #1
washoutbeach
Default Holden hates it's customers...
A mate of mine spends 70k on a beefy commie a year or so and gets the extra warrantee. That's close to the average salary.
Between 12 and 13 months later, the battery carks it after about 30 mins of illuminating a front of a house ( moving in ). I remember when they would glow for days!
He rings holdens famous roadside assistance only to be told the service expired a short time ago and that the fat lady had sung.
So now he has a poor impression of gmh. He thinks they are uncaring.
Suffice to say lads that his next expensive muscle car will be one of ours.
washoutbeach is offline
Old 13-05-2012, 08:38 PM   #2
pottery beige
Default Re: Holden hates it's customers...
so.. he left his lights on without the engine running.. ends up with flattery battery.. and its someone elses problem.......
pottery beige is offline
Old 13-05-2012, 08:43 PM   #3
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Jump start it and be done with it.... Battery isn't finished, just flat.
Head lights that stayed on for days??? Thats a first!
___________________________
Yellow_Festiva is offline
Old 13-05-2012, 08:44 PM   #4
Professor Farnsworth
Fossil fuel consumer
Professor Farnsworth's Avatar
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
it's not Holden's fault that he drained the battery.. surely with a jump or trickle charge it'd be fine again once it goes for a good half hour run or so to charge it via the alternator..
2024 Audi RS 3 Sedan - Mythos Black
2024 BMW M240i - Zandvoort Blue
2023 Skoda Superb Sportline Sedan - Steel Grey
Professor Farnsworth is offline
Old 13-05-2012, 08:48 PM   #5
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
I don't think 30 minutes of leaving the headlights on would flatten a battery dead flat, or kill it completely if the car is off, unless ignition is on as well.
And anyways if you're going to do that, leave the car running.
When you start completely discharging your average normal car battery, you'll shorten its life quite quickly, they don't like being run flat and being charged up again, that is deep cycle battery territory.
My Focus battery dropped a cell, was rooted and I didn't do anything like that, dodgy Motorcraft battery for you, another Focus owner had the same issue, it wouldn't hold any charge, at one stage I couldn't even roll start it as there was nothing keeping the ECU going.
Then I couldn't jump start it because the old man's Mazda 323 didn't have enough juice to crank her over fast enough .
Falcon saved the day.
Franco Cozzo is offline
Old 13-05-2012, 08:50 PM   #6
naddis01
naddis01's Avatar
Don't you need some special sort of charger with the VE? One of my mates had an earlier VE which had endless electrical issues including multiple dead batteries but he was unable to charge it with a normal charger. He ended up getting rid of it and went back to a VZ.
naddis01 is offline
Old 13-05-2012, 08:51 PM   #7
MrEL
Sick Puppy
MrEL's Avatar
Does your mate want them to change his tyres too because they wore out with driving?
Maybe Holden should be caring enough to fill his fuel tank every time it needs doing as well.
MrEL is offline
Old 13-05-2012, 08:57 PM   #8
Ben73
Ben73's Avatar
If I have to use headlights to see at night, I just leave the engine running. Helps when it's not your car or fuel
Surly if your mate can afford a 70,000 car and a new house he can leave his car idling for 30 mins and spend about an extra dollar on fuel.
Is extensive idling actually bad for you vehicle?
Ben73 is offline
Old 13-05-2012, 09:00 PM   #9
DaveD
DaveD's Avatar
I think the title of this thread is a bit harsh TBH.
DaveD is offline
Old 13-05-2012, 09:00 PM   #10
well, yes.
Old 13-05-2012, 09:02 PM   #11
chrisfpv
Browsing here and there..
chrisfpv's Avatar
Does your mate want a GMH rep to come wipe his bum every time he goes to the toilet too?
You'd think someone who has the money to splash out $70,000 on a car would have some sort of common sense.
chrisfpv is offline
Old 13-05-2012, 09:03 PM   #12
Franco Cozzo
Thailand Specials
I've had no issues with my car doing it, the only problem I could possibly see is that it might overheat because besides the thermofans coming on ocasionally, there isn't any air taking the heat away from the radiator.
But I've left my EL Falcon idling for 2-3 hours in the driveway with no issues in one hit, I've used about 60L of fuel just idling it away in the driveway since I've had it. The only issue I see is that the alternator output dropped to 11V with all the electrics on, but I think thats because the alternator is probably rooted as its covered in power steering oil, which craps out the brushes and slip rings.
Had no overheating issues at all, same with my WS Fiesta and LV Focus, both idle for periods of around 30 minutes every morning.
Old 13-05-2012, 09:05 PM   #13
AndyXR6T
AndyXR6T's Avatar
I like where this thread is going
AndyXR6T is offline
Old 13-05-2012, 09:05 PM   #14
But I've left my EL Falcon idling for 2-3 hours in the driveway with no issues, besides the thermo fans going on/off and same with my Fiesta and Focus.
i once became distracted at the mechanics and left my old EL Ghia I6 idling for 20 minutes.. the next week it was back there for a head gasket
mind you it's not the first e series with a blown head gasket but it was the catalyst for it going
there are many areas of an engine which can suffer from excessive idling
anyway back OT, the thread is a little redundant.
Old 13-05-2012, 09:05 PM   #15
Nikked
Oo\===/oO
Nikked's Avatar
Sounds like your typical HSV buyer, clueless crybaby...
"I left my lights on and the battery went flat, but its not my fault"
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline
Old 13-05-2012, 09:06 PM   #16
nstg8a
3..2..1..
nstg8a's Avatar
good to see common sense prevails here, even when it is the other team involved.
i agree with all who have posted, except the op lol
Originally Posted by pottery beige View Post
Happy mcgadget meal orphan mcboofhead
nstg8a is offline
Old 13-05-2012, 09:07 PM   #17
HUNTER8
HUNTER8's Avatar
Tell him to stay a Commodore driver. Heaven knows we have enough Ford drivers whingeing about nothing without having an ex Commodore driver doing the same.
Ford Performance Enthusiasts
HUNTER8 is offline
Old 13-05-2012, 09:07 PM   #18
Franco Cozzo
Thailand Specials
Probably all the better it blows in my driveway rather than when its on the road I guess
Old 13-05-2012, 09:07 PM   #19
Auslandau
335 - STILL THE BOSS ...
Auslandau's Avatar
I think we get the drift on where this one is heading .......
Gotta say though ...... to change brands because the battery went flat because the lights were left on ...... bit fickle?
'73 Landau - 10.82 @ 131mph
'11 FG GT335 - 12.43 @ 116mph
'95 XG ute - 3 minutes, 21.14 @ 64mph
101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong!
Clevo Mafia
[SIGPIC][/SIGPIC]
Auslandau is offline
Closed Thread
