Old 19-03-2012, 09:47 PM   #1
lamborghinifan
lamborghinifan's Avatar
Default Any ideas on what this ticking noise might be?
I have a ticking noise coming from the rear right of my 04RWD 4spd terry.
Sounds like a credit card/cable tie on bike spokes.
Only does it whilst driving, gets faster with vehicle speed, but seems to be related to engine RPM, ie at the same speed it ticks faster in 3rd than 4th.
I'm hoping it's not, but seems to be transmission related, anyone got any ideas? My mechanic hasn't any ideas, we originally thought rocks in tyres. I can only hear it with my head between my legs in the rear passenger seat, wife can always hear it.
Any ideas for a man going crazy?
lamborghinifan is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 10:02 PM   #2
StockieXR6T
StockieXR6T's Avatar
Default Re: Any ideas on what this ticking noise might be?
Sorry, it was too hard to refuse. If it were road speed I'd look at the cvs, seen problems on lowered territories. Could be a grommet missing so the noise is transmitting from elsewhere.
Black Mamba Racing Components
4B Fabrication & Performance Tuning
www. 4bfabrications.com.au
StockieXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 10:02 PM   #3
snappy
snappy's Avatar
Movement in the brake pad , you most likely have a pad that is a bit smaller or a caliper that its groove is a little larger and it moves making a tick with the revoultion of the wheels . Had it with 2 of my cars 1 ford one another make , both fixed by going to a after market pad
snappy is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 10:12 PM   #4
GCRXR6
GCRXR6's Avatar
Verrrry uncomfortable way to hear a sound I must say. It is amazing though where sounds can only be heard, or where they "seem" to come from. That sound you describe sounds like an interference from a faulty capacitor, in the vehicle somewhere, ticking in the radio. Is you radio on when you hear this sound. I've heard this in my EF. I remember it being a capacitor but can't remember where. (Can't find the repair report neither, after 12 years ).
Your radio does not have to be turned up neither. Just as long as it's on or off.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better!
GCRXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 10:18 PM   #5
Hayden1
Yep could be as simple as interference somewhere along the audio system. It will be the same volume no matter how loud or low you set the volume. Put your head next the speakers and see
Hayden1 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 11:47 PM   #6
James_bf
Rear passenger seat - that's above the fuel pump.
If it is engine speed related and NOT road speed related, I'd start there.
Maybe it's normal.
James_bf is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 11:56 PM   #7
In Focus
One out of left field, but I had something similar happen to me. Do you have mud-flaps on the rear wheels? I had a loose/misplaced one on an EF Falcon which would rub on the tyre at slow to moderate speeds (though the sound would disappear at a higher speed), producing an alarming sound.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
In Focus is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2012, 09:42 AM   #8
joolz
Possibly ABS ring touching on the sensor?
joolz is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2012, 10:17 AM   #9
Full Noise
Life begins at 40
Full Noise's Avatar
Location: Melbourne. Socialist capital of Victoriastan.
This could also be a wheel bearing, check all of them.
I hope you haven’t upset any Syrians around your neighbourhood?
Also, could you please post a pic of you being driven around with your head between your legs, I’d like to blackmail you later with it.
Marriage is like a deck of cards. In the beginning you’ll have hearts and diamonds. Towards the end, you’ll be looking for a club and a spade.
Justice is what you get when you run out of money.
Full Noise is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2012, 11:28 AM   #10
sgt_doofey
sgt_doofey's Avatar
Another one a little out of left field...
The little weights used to balance tyres on the inside of your rim hitting the brake calliper?
Cheers,
Sam.
Old 20-03-2012, 06:54 PM   #11
lamborghinifan
(checks in driveway car hasn't gone boom and there's no pile of cinder, no only have upset aussies recently, they're all too busy watching footy to blow anything up)
thanks for the ideas a hundred an one things to check now.
rear pads have been recently been changed, what would be best way to try and find a click there, swap them left to right and see if the sound follows?
Old 20-03-2012, 07:02 PM   #12
lamborghinifan
by road speed, when i drop it back a gear at constant speed it seems to jump a little inline with engine speed, but not sure if it's the lurch from the change itself
Old 20-03-2012, 07:03 PM   #13
lamborghinifan
hmm, unless the back wheel has gone out of shape, it's not touching when it's stopped, and there's no scoring on the inside of the rim i can see
Old 20-03-2012, 07:05 PM   #14
lamborghinifan
Maybe it's normal.
should the frequency then change with the engine being revved in neutral?
Old 20-03-2012, 07:28 PM   #15
StockieXR6T
Possibly not as the demand for fuel dosent change much free reving.
Have we decided whether it is road speed of engine speed? Is it the same speed in different gears? Does the drivetrain have to be under load, does it alter relative to load?
Joel
Old 21-03-2012, 07:29 AM   #16
sgt_doofey
sgt_doofey's Avatar
You won't see it on the rim, but on the weights used to balance the tyres.
What happened in our Peugeot is that the tyre places stacked those sticky weights on top of each other and when I had the front brakes pads replaced, the calipers were a little wider due to the thicker pads and the wheel weights would catch the caliper on their way around.
Even if you jack the car up and just spin the wheels around, if it's that, you'd hear them hit without having to take the wheel off.
Cheers,
Sam.
Old 21-03-2012, 08:31 AM   #17
aussie muscle
aussie muscle's Avatar
it's amazing how many respondents didn't read that bit.
sounds like it would be engine or gearbox or electrical rather than wheels, etc.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
