Old 17-03-2012, 03:06 PM   #1
zakjames
zakjames's Avatar
Default For those that know their audio
Did not know where to post this so I figured this would be a decent place to start. Ive finally finished installing all my audio equipment including JVC headunit, JBL cross overs for the front and OA amp for them. Being the first time i've ever had tweeters i've never known how they sound etc. However they have a constant static distortion sound sound coming from them always.
On higher/mid range volumes I cant hear it but I know its there.
Is it just the way my amps tuned at the moment or is this normal operation of tweeters.
Many thanks for any advice.
-Zak
zakjames is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2012, 05:21 PM   #2
tickfrd6
Default Re: For those that know their audio
You might want to check the grounding. I've grounded my amp to the rear seat bolts.
Au xr6: tickford kits, tickford 17s, momo T Bar and wheel, leather, lowered on ultra lows, 2.5" cat back with hot dog muffler, K&N panel filter and loving the car as a P plater
Future mods:
19" staggered wheels
Clear side indicaters.
That is all
tickfrd6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2012, 07:53 PM   #3
brad`
The Monty
brad`'s Avatar
did u run the RCA leads and the remote/power wire on seperate sides of the car? i know that is causes static in the speakers when turned up,
Tweeters should be no diffrent to normal 6"/5x7"/6x9" etc only diffrence is its dedicated treble so its a lot crisper sound
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 07:41 PM   #4
zakjames
zakjames's Avatar
the RCA leads do pass over the main power wire, is it worth starting by moving these around? My ground is on the handbrake lever bracket bolt, a good earth.
Cheers guys.
