I've just picked my car up from the local ford dealer after having the bushes replaced in the diff,axles seals replaced, a service and a few other bits and pieces.
I got the ford dealer to do the bushes because they were charging $750 and everyone else quoted over a grand. Anyway I notice on the way home that the diff now makes a heap more noise. I know that the new bushes will transmit a little extra noise into the car but this is a lot louder than it was when i dropped it off. Diff whine sounds like a taxi with 900,000 on it now. Before the work was done I would have said it was reasonably quiet for a falcon with 140k's on the clock. I rang the dealer straight away and voiced my concern, they sort of laughed me off, when I laboured the point they eventually said bring it in tomorrow and they'll look at it. I can see where this is headed allready "that is normal noise"/ "no it's not". "it's just the new bushes"/"no it isn't" Even my girlfriend noticed and I haven't been on the highway yet. Do you guys think I have a chance of getting something done or am I just going to give myself heart burn and frustration for weeks? |
Abuser of Charvels
If they are standard Ford bushes they won't be any noisier than before, it the aftermarket ones that transmit more NVH.
Noticed th same with my FG. Dealer replaced the diff bush under warranty (god knows why it failed, as the car is babied) and I can feel a slight high frequency vibration at around 100 kph now, nothing major though but it could be on the OP's case that the driveline wasn't rebalanced too well.
I believe the prop shaft has to be rebalanced on the car after being disconnected to get it right. |
yes blockhead83, you would think that a new bush being firmer would transfer a bit more road noise than an old spongey one would`nt you, hard old tyres can make a racket too, could it also be wheel bearings? got any oil in the diff?
Kieron : Noticed th same with my FG. Dealer replaced the diff bush under warranty (god knows why it failed, as the car is babied) and I can feel a slight high frequency vibration at around 100 kph now, nothing major though but it could be on the OP's case that the driveline wasn't rebalanced too well. I believe the prop shaft has to be rebalanced on the car after being disconnected to get it right. i have a theory kieron some of these diff bush problems occur earlier with certain types of wheel /tyre combo`s(lower profile type), also people tend to run high tyre pressure to save a couple of dollars in fuel, the bump/shock absorbing action tyres once had is very little these days, i live in an area bounded by bloody speed humps every where, i baby mine to, especially suspension wise, 200000 k`s same ball joints suspension bushes on my old au(touch wood/my head) and she`s still pretty tight. i`m a firm believer a bit of bulge in the tyre is a good thing(within reason) depending on the road surface. |
#5 | |||
my understanding is it is a 7 hour job at the dealer as the the entire rear end & brakes are normally removed, but my mechanic who has done quite a few, suspends everything on stands so as not to remove all from the vehicle, so drive shaft is not disconnected in my case, I wonder if the noise has anything to do with balancing shaft, not to say it does not but?
I contend that for a nation to try to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle. - Winston Churchill |
#6 | |||
Fixing Ford's **** ups
I know the early BA Turbo diffs had a whining issue, which they fixed later in the run. Not sure of when the changeover period was though.
Tyre pressures with low profiles you do have to be a little wary of. Running them too soft causes premature failure. Unfortunately the way I pick it up, is taking a tyre off the rim and seeing it there. The whine issue. If they try fobbing it off, ask if you can take a car from the lot for a test drive, with mechanic in tow and see if it makes the same noise (Which I doubt a lot car would). Then run with that.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
Just got back from the dealership and after a little too and fro about new bushes and how much more noticeable they would make any diff noise, I took a mechanic for a drive, once they heard the whine even at low speed they agreed that something may be amiss and are going to look at it next week.
So we'll see how it goes.... |
he acknowledges somethings amiss so that`s a step in the right direction.
#10 | |||
Mmm. When youre happy they send a mechanic around to your house with some lippy on and a bunch of flowers.
XC GXL Warm 351c AOD ![]() 09 VE SV6 Sportwagon ![]() BA Fairmont Ghia ![]() |
#12 | |||
#13 | |||
Normally the service centre doesn't go this far. So it seems like the OP had half a win. Just wait for the other half to crop up.
#14 | |||
Mr Hoon
