Old 03-12-2011, 12:02 AM   #1
_Ben
_Ben's Avatar
Default AU died :(
Hey guys
Today I was driving my AU around (AUII 6 cyl auto), and the fuel gauge seemed a bit... wrong, so I pulled over to restart my car. I turned it off, however all the interior lights just died too... the aerial stayed up as well. is this indicitive of blowing the main fuse? I messed around with the fuse box, disconnected and reconnected the battery and bam, all the lights go on, and aerial goes down. however when I went to restart my car, everything stopped working again.
What do I do D:
Thanks, Ben
_Ben is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2011, 02:35 AM   #2
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Default Re: AU died :(
Loose battery terminal or main earth would be my guess. Looking at the engine under the exhaust, you will see a thick cable bolted to the side where the engine mount is - try tightening that. Also try cleaning your battery terminals and ensure they're contacting properly. Failing that, borrow a battery as yours may have dropped a cell...
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
