Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 18-11-2011, 02:33 AM   #1
GTsteveMkII
EL GT 082
GTsteveMkII's Avatar
Default 6 x 4 Brembo's for Territory
Hi guys, I was just wondering if you could help with some info on fitting the 6 piston front 4 piston rear Brembo brake package from an FG to an '06 Territory Turbo Ghia AWD? Can I use the original Brembo front rotors and DBA rear rotors? Can I even use the 4 piston rear brakes?
Any help would be much appreciated.
Cheers, Steve.
HIS - 1997 30th Anniversary Falcon GT
HERS - 2013 SZ Territory Titanium
DAILY - 1998 Fairlane By Tickford
GTsteveMkII is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2011, 08:46 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: 6 x 4 Brembo's for Territory
Cheers, Steve.
Steve the rears should fit straight up but the fronts will need different brackets and also the front and rear brake hoses will be different.Rotors are the same.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 18-11-2011, 11:07 AM   #3
GTsteveMkII
EL GT 082
Awesome! Thanks for the reply. Can you guys supply the new brackets for the front and the braided lines? I thought the rotors would be ok but thought I should check since FPV used the solid rotors rather than the slotted and cross drilled Brembo/DBA set it from the Falcon range.
Old 18-11-2011, 01:24 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I will pm you
MATTHEW PEARCE
Phone 02 9609 1101
