09-11-2011, 05:27 PM | #1 | ||
I Like Turtles
Firstly, sorry if this is in the wrong section.
Anyway, I just got my automatic serviced and when I picked the car up the guy brought up the fact that I drive in 'Economy' mode and that I shouldn't. I was a little confused because I always thought power mode was only really used for towing (as stated in the manual) rather than city driving. Now I'm not too sure if I should take his word for it, although he seemed quite professional and has probably been in the business a while. He also told me a whole heap on why it's beneficial, rah rah rah and that he spoke with the chief of Borg Warner but I'm still not convinced. Do tell... |
09-11-2011, 05:32 PM | #2 | ||
The Experience...
Well I had an auto EF XR6, so not all that different to yours. And i my experience you are completly right, only under heavy load would I turn Econ off... The only diff I found was with power mode on, it revved out more between gears with the same amount of throttle which in my head, make perfect sence for towing conditions etc.
Would of been interesting to hear his opinion though in detail... Diversity is golden...
Her Daily: BF XR6T ZF
His Daily: FGX XR8 ZF Their Pride: T3 TE50 Manual |
09-11-2011, 05:36 PM | #3 | ||
I Like Turtles
He mentioned something about lockup. Sorry I can't get too technical as I was still getting over the fact that I was driving an automatic wrong....somehow.
09-11-2011, 05:45 PM | #4 | ||
No doubt reving through the range is fun, but it eats fuel too much, thats why i keep it in normal.
09-11-2011, 05:47 PM | #5 | ||
Your owners manual is your guide......
Personally it sounds like he is feeding you something
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
09-11-2011, 06:13 PM | #6 | ||
Doesn't the "power" button change the ECU programming and make the engine produce more horsepower?
...at least that's what guys told me years ago when I first saw Commodores with that button on the console... |
09-11-2011, 06:17 PM | #7 | ||
Ford Fiesta
You sure he's not after you to be back there in 12 months needing a full transmission rebuild and lining his pockets with some $?
Never heard of that before. Power mode holds gear longer to provide better accelaration under load (e.g. towing) ... which obviously consumes more fuel. I imagine it has some effect on transmission wear too. |
09-11-2011, 06:31 PM | #8 | ||
I Like Turtles
Yeah, he probably saw my P-Plates and assumed I'm a hoon and that I will rip it into 'er at every possible moment and blow my gearbox. Business is also extremely bad where I live so you might be right.
But another reason why I posed this subject is because my mum's Hyundai Excel has an economy and normal button. I assumed normal in that instance would be power in mine. My car is no Excel though. |
09-11-2011, 06:32 PM | #9 | ||
No longer a Uni student..
Now, this is just what someone told me, so I cannot comment on whether it is true or not.
Basically at 50km/h in econ mode the gearbox is right on the shift point between two gears, so if you go up an incline or something it will constantly switch between the two gears. Turning off 'econ' mode stops this by changing the shift point. |
09-11-2011, 06:42 PM | #10 | ||
this is my take on it, i always drive in power mode(always have), rightly or wrongly, i would rather the auto change into gear at a slightly higher rev, so that way the the transmission line pressure is higher so therefore having a tendancy to have less band slip and prolonging the life of the auto.
09-11-2011, 06:47 PM | #11 | ||
lol im with the mechanic.... because in normal/power mode the transmission will happily drop back a gear with minimal throttle when going up inclines which otherwise in economy would hold & chug along in top gear and feel far from economical
in other words, makes the BTR more zippy around town |
09-11-2011, 07:37 PM | #12 | |||
Happy Wife = Happy Life
333 lazy RWKW, Thanks Chris, Theo and Ryan at BLUE POWER G6ET 2010 Seduce. Tax return = GTX upgrade DONE |
09-11-2011, 07:43 PM | #13 | ||
When I used to have an EL. I did pretty much 240,000k's in economy mode and the trans only had two oil changes in it's life. Trans was faultless.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily). Tuned by Hallam Performance |
09-11-2011, 07:46 PM | #14 | ||
Cobblers!
My Fuel Economy got better in Normal Mode, compared with Economy Mode. To the tune of about 50 Kms to the tank, mainly because the engine wasn't labouring and slipping against the torque converter. I can't drive the car in Economy Mode any more, because it does my head in.
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
09-11-2011, 07:54 PM | #15 | ||
I had a EB that would get better economy in power mode but that economy was the tune of 16-17L/100km.
09-11-2011, 08:38 PM | #16 | ||
Peter Car
I was under the impression that in Power mode the shifts are a bit firmer, and don't slur as much as in Economy, which reduces slippage and therefor heat, and therefore increases the trans longevity.
I'm pretty sure thats true as well. I would believe what he's saying is true. |
09-11-2011, 09:02 PM | #17 | ||
The Experience...
But theres a couple of testimonies in this thread that they've had there cars in a couple of hundred tho kms on econ with no hassel. Im sure it only revved it out more. To me it like driving a manual, same throttle but rather then changing at 2,800, I change at 3,300. There are both pros and cons eithet way. Econ on 24/7 would after *00,000kms put heavier wear on your box and even your engine to a degree. But how much so is the question.
09-11-2011, 09:59 PM | #19 | |||
YE-US! Wait. I don't know
This all depends on how they drive the car and where as well. Where I grew up, power mode is pretty much essential, otherwise you'd be in third or fourth gear going up a steep incline, and that's really not good. The wear and tear damage in the end, is not going to be a huge difference, especially since its only a minor amount of band slip thats being prevented (from memory, I talked to a lecturer about this aaaaaaaaages ago). The problem occurs, as my mum found out in the lexcen, is if you tow something without economy mode off.... yeah... she learnt, to not tow anything, ever again. Or maybe it was in power mode, but the car was that shot it kicked itself anyway, can't remember. What I do remember is th D&M I had with her about transmissions after Anyway, I digress. If you keep it in economy, you can always manually downshift and upshift through the gears when you need to ;) And that *should* be just as good as keeping it in Power mode
"Well. Apparently you're looking for a lion-snake named Harriet." Daily: '06 BF XL Ute,Shockwave Blue, Column Shift, eGas BEAST.
Gone: 77 HZ panel van, 253, column. The Weekender: '06 BF Pursuit, Toxic, lumpy af |
09-11-2011, 10:16 PM | #20 | ||
I really doubt it makes a significant difference under normal driving circumstances. In hilly country or towing or drag racing, fair enough, put it in power mode. I keep mine in economy 99% of the time, it suits my driving style better. Means I can get to 60 quicker and keeps the revs under 2000 rpm because it changes through 1, 2, 3 really quickly whereas in power mode it would obliterate my already poor fuel economy. If I need to go up a steep hill I just drop it back to '3'. The only thing I don't like about economy mode is that it slurs in and out of overdrive at around 80/85 km/hr which can be annoying if you're in an 80 zone.
2011 FG XR6 Sedan |
09-11-2011, 10:47 PM | #21 | ||
You dig, we stick!
In economy you may be cruising below the torque convertor's lock up speed. When cruising in 4th for example at below the stall speed then that leads to overheating and wear. You'd rather it be "locked up" in third with higher revs, about 2000rpm - not good for fuel but there's no wear resulting from slippage.
"....You don't put the car through engineering" - Rod Barrett. |
09-11-2011, 10:54 PM | #22 | ||
Lockup in our XR6T BA is 62kmh/r(18's)in Perf D,annoying to be honest.58 would be better.
(Above^^^^)This is why highstalls and tall diff gears arent reccomended as well.If you do alot of cruising at city speeds then sitting 2-3000rpm of the stall speed will generate exessive heat. |
09-11-2011, 11:30 PM | #23 | |||
Cobblers!
I don't let mine have 4th, unless I'm on the highway anyway.
10-11-2011, 04:35 PM | #24 | ||
Greys tuf too :-)
Perhaps your box is a little worn so he is suggesting to drive in perfromance mode so the converter doesnt lock out, that way all slip is taken up in the convertor and not in the box it self. Pretty sure in performance mode they dont lock out at all, even when they are above the stall rpm.
I know at 100kmh in my BA if I bump it across to performance the converter unlocks and it picks up a few hundred rpm. |
10-11-2011, 04:43 PM | #25 | |||
Cobblers!
My Territory didn't give you 4th in Performace Mode, and did not lock up 4th in SSS mode, but would in D.
10-11-2011, 04:48 PM | #26 | ||
off in outer space
i drive my Territory in Perf mode in anything under 80k's
i get better l/100k then the wife who drives in nom mode all the time
"Always be yourself... because the people that matter, don't mind and the people that do mind, don't matter".
10-11-2011, 06:01 PM | #27 | |||
Peter Car
10-11-2011, 11:57 PM | #28 | ||
I Like Turtles
He said my gearbox is in excellent condition. My EL has only done 168xxx K's.
I'm still confused on this lockup business though. Can anyone please elaborate as the guy mentioned this word quite alot? |
11-11-2011, 09:54 AM | #29 | ||
my BF 6 speed looses a gear when you switch to power mode, so i only use it for hooning.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
11-11-2011, 02:28 PM | #30 | ||
Most BTRs work as a 3 speed auto in power mode, just like the good old days of C4s and FMXs. In Econ they are capable of selecting (4th) odrive and then susbiquently lock up (which under certain circumstances in some models will maintain on a downshift to third). Using a range of inputs the box will drop out of lockup and or 4th as load increases. They are usually pretty smart and don't hunt. If you find the box hunting select power mode or a prefered gear. Thats my experience. Some one asked what lock up is... it is a clutch that operates to dirrectly join the gearbox input to the crankshaft, thereby eliminating all slip by the torque convertor and saving fuel (usually).
