Old 09-11-2011, 06:17 PM   #1
79FordEsky
79FordEsky's Avatar
Default 79 Ford Escort Parts Needed First Post
G'day
I am looking for ford escort Mk2 square headlight Parts for my Ghia sedan.Looking mostly for grille,headlight bucket,trim pieces and ghia wheels but looking for any parts i can possibly get.
Thank you and this would be greatly appreciated.
79FordEsky is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2011, 08:58 PM   #2
K10wN
K10wN's Avatar
Default Re: 79 Ford Escort Parts Needed First Post
Check the VIN plate and I'm sure you'll find it's a BC Escort. Mk2 is 1975 to 1977. I bought a 1975 Mk2 as a parts vehicle for my 1978 BC and alot of parts didn't fit.
** 2000 Ford Cougar SW 2.5L V6 **
** 1978 Ford BC Escort Coupe 1600 **
** 1978 Ford Cortina TE Ghia **
K10wN is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2011, 09:22 PM   #3
Russ
Russ's Avatar
eBay has some parts available if you want to have a bit of a look. Failing that you could always try a Ford wrecker and see if they can track some parts down for you
http://www.ebay.com.au/sch/i.html?_n...=p3286.c0.m359
Old 10-11-2011, 11:52 AM   #4
feral
Ask over here you might get a hit as there a few more escort lovers on board.
http://www.classic-ford.org/cfp/
or
http://www.rsmotorsport.com.au/forums/index.php
ZJ Fairlane 351C
SY Territory
Skicraft Excel 350 Mercruiser
feral is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2011, 05:30 PM   #5
79FordEsky
79FordEsky's Avatar
Thanks fellas your help is greatly appreciated.I will follow up on the leads.
Old 12-01-2012, 07:43 PM   #6
Forte
What parts didn't fit???? Ive had a 76, 2x79 and an 80 model and all parts were interchangeable. and i also had a 71 and even stuff from that were interchangeable
Forte is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2012, 09:54 PM   #7
smh00n
State of Confusion
I have some of the side mouldings for a 4 door here. Will check exactly what ones I have if you need them
2016 FGX XR6 cab chassis
1970 Mustang base Sportsroof
smh00n is offline   Reply With Quote Multi-Quote with this Post
