Old 01-11-2011, 08:51 PM   #1
Lazy Peac*ck EB
Default What sort of part is it?
Im looking at the front end of my falcon after I collided with a speed sign!! Im replacing a radiator, air conditioning condenser and that other small thing that when i pulled it out, oil came out of it. It is another cooling device of some form. When you look at the car, it is on the left hand side right infront of the condenser.
What is it so I can get another one!!
My Daily
VT Wagon, stock. I hate Holdens, but the wagons look better than the Fords. Shame.
Ma Project Car Now
Grandpa ED with ma hectic louvres, LPG, stock as she goes, surprisingly reliable and goes ****in hard on gas!
Toy Car
XF UTE with XR6 Headlights, Chromed 12 Slotters, 4.1L 250 Crossflow, Triple Holley Carbs, Stage 4 Crow Cam, Extractors, 3" Exhaust, Yella Terra Roller Rockers, 5 Speed TREMEC Manual Box, 3.45 9" LSD. SOLD :(
Come at me Holden.
Lazy Peac*ck EB is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2011, 08:56 PM   #2
Spanrz
Hmmmmmmm!!
Default Re: What sort of part is it?
Accumulator/Receiver Dryer? Round thing with 2 pipes and a sight glass?
Your best bet is a Auto Electrics joint that does AirCon's. Once you break the seal on these things, you need a new one, never a secondhand one.
Spanrz is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2011, 09:10 PM   #3
dave351cid
playing in my big shed
dave351cid's Avatar
would it be an oil cooler for the auto tranny ?
looks like a small radiator with inlet and outlet pipes that run back to the gearbox. usually fitted aftermarket to bypass the standard oil cooler that is inside the normal engine coolant radiator. should be able to pick up a new one at most parts shops. they are not car model specific.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2011, 10:53 PM   #4
XR Martin
XR Martin's Avatar
You dont have a camera?
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 01-11-2011, 10:55 PM   #5
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Or a small cooler for power steering as quite a few Fords of that era had fitted.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2011, 11:26 PM   #6
Lazy Peac*ck EB
Yeh I do have a camera but I don't know how to reduce the image size to be able to upload it. :( Umm someone tell me how to reduce the size and I will upload a photo haha
My Daily
Ma Project Car Now
Toy Car
Come at me Holden.
Old 01-11-2011, 11:41 PM   #7
Jim Goose
Oil? Ummm
Oil as in engine oil or oil as in transmission/ power steering oil?
Is it a cooler or just a pipe?
Pretty sure the EB just ran a U shapped pipe as a power steering cooler.
Transmission cooler would be probably be aftermarket.
If you follow the lines connected to it, it will tell you what its for.
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2011, 07:01 AM   #8
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Just go into the camera settings under resolution/photo quality and change it to the smallest setting, usually .3 mp then you can upload it direct using your aff allocated space.
Old 02-11-2011, 07:43 AM   #9
prydey
Rob
prydey's Avatar
i'd say dave351cid is on the money. sounds like trans cooler to me. is the car optioned with towbar? back then, if you optioned the towbar i'm pretty sure the car got a extra external tranny cooler.
dryer is on the right hand side.
Old 02-11-2011, 08:18 AM   #10
Mitch_
upload the photo to imageshack.us - they'll resize it for you
Mitch_ is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2011, 10:01 AM   #11
Fev
Fev's Avatar
If its the left side if your facing the front of the car I'd say its a Tranny cooler too
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
