Old 19-09-2011, 09:34 AM   #1
Seduce XR6
Default Weight Balance
Might sound like a silly question though I will ask it anyway as am sure somebody on here would know the answer, lets see who really is the Ford Guru on AFF
What is the weight balance on a FG I6 Falcon as in front to rear etc?
I would guess they are front heavy at around 65% front 35% rear, any takers?
Seduce XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2011, 03:02 PM   #2
SteveJH
No longer a Uni student..
Default Re: Weight Balance
Not me, but i doubt the weight distribute is that far to the front. How much do the spare and IRS weigh?
SteveJH is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2011, 03:35 PM   #3
MAD
Petro-sexual
MAD's Avatar
Which gearbox?
- The Story
Old 19-09-2011, 03:45 PM   #4
FalconXV
FalconXV's Avatar
55.5% front : 44.5% rear.
FalconXV is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2011, 03:53 PM   #5
Seduce XR6
ZF Box, thanks guys I did not think it would be that far to the front (65/35) specially on the NA 6 however I thought me saying 65/35 might just make some more keen to tell me I was wrong & thus give me an answer lol
So assuming he is right FalconXV gets the prize which is simply a ty from me & Recognition as being a Ford guru
Old 19-09-2011, 03:56 PM   #6
Seduce XR6
So next question would be how much weight would you need to transfer to the rear to make it 50/50 & could that even be done?
And will the upcoming 2 Litre have a better balance?
Old 19-09-2011, 04:09 PM   #7
MAD
Petro-sexual
MAD's Avatar
50/50 isnt always the best. The way it transfers the weight, under different conditions, is more important.
- The Story
Old 19-09-2011, 04:14 PM   #8
Hally
two fat blokes in the back seat?
Hally is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2011, 04:17 PM   #9
XR6_661
Cane Farmer
XR6_661's Avatar
That'll do.
1994 ED XR6T - Cobalt Blue.
2009 FG XR6 - Black.
Originally Posted by Tex
I couldn't give a crap how many are in their family, what gay passtimes they paticipate in, or whether they have a cat, dog or a freaken fish.
Keep your stinking family to yourself god damn it.
XR6_661 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 04:57 AM   #10
Seduce XR6
lol so where can I hire a couple of Sumo's?
Old 20-09-2011, 04:59 AM   #11
SteveJH
Moving the battery to the boot would have to make it pretty close.
And most likely.
Old 20-09-2011, 05:20 AM   #12
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
The I-6 versions are most likely 55% F 45% R but the iron block 5.4 Boss probably changed that to more like
60% F 40% R which is similar to a FWD Cars weight balance and probably why the V8s used to feel a touch nose heavy...
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 06:08 AM   #13
SteveJH
How much does a typical lead-aid battery weigh? If you moved it to the boot...multiply that by 2 and you get the rearward weight shift.
Would have to be about a 50kg net change?
Old 20-09-2011, 07:51 AM   #14
sudszy
If we take the 55.5/45.5 numbers at face value, thats about 935/765 on a 1700kg Falcon.
To be 50/50, 85kg would have to go from directly above the front wheels to directly above the back wheels.......or put about 2 x 85kg in the back seat, yep two fat blokes.
Yep, you can move lighter things further past the axles to achieve the same effect, but that can affect the dynamics in other ways.
Really though the cars are setup pretty well, if they started at 50/50 empty they'd end up horrible once you've put the driver in and with any sort of a load in the boot or rear seat.
sudszy is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 08:55 AM   #15
aussie muscle
aussie muscle's Avatar
reminds me when i had to fat blokes get in my valiant. they both sat on the passenger side, and the weight changed the handling of the 25 yo suspension that the car wouldn't drive straight!
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 10:13 AM   #16
dimka100
While generally speaking 50/50 Front to Rear weight distribution is a good thing, it’s not always the best outcome the engineers are trying to achieve. When it comes to car handling the car’s static (stationary) weight distribution is not as important as the actual weight distribution when the car is moving. For example:
When the car is braking the weight distribution will always move Forward (i.e. front biased)
When the car is accelerating hard the weight distribution will always move backwards (i.e. rear biased)
When the car is turning the weight distribution will move to the front and the cornering side, and then progressively balance back to the centre while moving rearwards as the car begins to accelerate out of the corner.
That shift in the vehicles mass will generate additional pressure on the tyres hence increasing grip, which will help when braking, accelerating, and cornering …
Many racing cars are actually setup to not be perfectly equal while stationary, however when driven at their expected speed they will achieve the required weight distribution for ultimate performance in the required circumstances
dimka100 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 10:15 AM   #17
XR6_661
Cane Farmer
XR6_661's Avatar
No need for that mate, go pick up a couple of fat chicks. It's like fishing with dynamite.
Old 20-09-2011, 11:24 AM   #18
sudszy
in most cases yes, but if the C of G is at axle height(which is effectively how formula one is setup) there will be no "weight" transfer effect.
Old 20-09-2011, 11:31 AM   #19
dimka100
Love F1, tyres in F1 make a huge difference to the setup and most of the suspension movement is actually in the tyres LOL also aero adds massive weight to the car and it can generate 5G under braking
Old 20-09-2011, 11:51 AM   #20
MAD
Petro-sexual
MAD's Avatar
That's actually not correct. The CoG is still above ground level (the point of contact of the tyres) so there will still be a weight shift under braking, accelerating, and cornering.
Body roll and pitch is affected by the difference in height between the CoG and the Roll Centres.
- The Story
Old 20-09-2011, 11:55 AM   #21
GTP-814
love the quad cams
Look on any public transport system & you will find a coulple of heavy weights
GTP-814 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 12:16 PM   #22
sudszy
Have to respectfully disagree there, any rolling/pitching is proportional to how far the C of G is above or below axle height. If the C of G is below axle height the front of the car will move upwards during hard braking that is caused by braking via wheels.
Though during cornering I do agree, the height of the c of G is an issue irrepsective of axle height as even a slight bump can cause roll while cornering and pitch the c of G over axle height, my comment was prefaced for braking.
Old 20-09-2011, 12:22 PM   #23
MexicanBatman
MexicanBatman's Avatar
fat blokes are 85kg now?
WOW
MexicanBatman is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 12:36 PM   #24
sudszy
WOW
LOL, thought that may get a reaction, ave male height = 178cm in Aus, at 85kgs that a bmi of 27, = fat bloke. (yes i appreciate there are muscle bound types(afl players) who arent carrying an ounce of fat, that might fit those numbers, but they are the exception)
Old 20-09-2011, 12:39 PM   #25
MAD
Petro-sexual
MAD's Avatar
Though during cornering I do agree, the height of the c of G is an issue, my comment was prefaced for braking.
Even if the CoG was at axle height, there are two lines of force in play; road-tyre-contact and CoG. If they are not inline with each other, there will be a moment created. Ergo a weight shift will occur.
The two examples (pitch;braking/accel & roll;cornering) are one and the same. If it is true, as you've said, and there will be no pitch under braking if the CoG is level with the axles, then there could be no roll because the CoG is still level with the axles.
- The Story
Old 20-09-2011, 12:42 PM   #26
sudszy
Yes, that is correct, but check my edit above.
Old 20-09-2011, 12:50 PM   #27
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
The Op asked about finding out weight distribution specs, I am thinking this has gone a little bit OT.
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 12:53 PM   #28
MAD
Petro-sexual
MAD's Avatar
My statements above apply to a perfectly flat, and smooth, surface.
There is a whole lot more to suspension setup than I know, but for this example it's a very simple physics problem.
While I still think this is sort of on topic. We should probably leave it at that.
Go have a read of some suspension setup books and see for yourself, that pitch/roll is caused by the forces induced by the tyre contact patch and the CoG. How those forces are used, is a funtion of the suspension design.
- The Story
Old 20-09-2011, 07:56 PM   #29
Seduce XR6
Yes I was thinking exactly the same, ty for the input
Old 20-09-2011, 08:05 PM   #30
Seduce XR6
While I can almost understand all that tech speak it does leave me a little lost though taking 1 part of it which I feel is relevent to myself & my reasons for asking is that if you have that many kilos of extra weight on the front would that not under hard braking make the extra weight more of an inluence than it would be under normal driving conditions thus making the not so bad balance as some have said rather bad?
As in a multiplier effect of sorts?
Moving the battery into the boot in one of those battery boxes sounds good though would you then lose some effect of the alternator as the cables would be much longer than they were under the bonnet?
