Old 03-09-2011, 02:42 PM   #1
den95deb
Default Diff leaking oil
Hi Just wondering if anybody has had experience with front diff seal leaks. 1999 au 272,000 klms
Dennis
den95deb is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2011, 04:33 PM   #2
Beer Baron
Default Re: Diff leaking oil
That would be the Pinion seal leaking. Slide under your car and try to wiggle the tail shaft up and down. Its ok to have a tiny tiny bit of movement but a lot of movement means your pinion bearing has excessive play in it which will stuff your crown wheel and pinion.
Get it checked as diff rebuilds are not cheap.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2011, 11:03 AM   #3
b2tf
not here much anymore
b2tf's Avatar
A mate has had this problem with his ute and it was a reasonably cheap and easy fix - but it was caught early.
RAM 1500
