Old 02-08-2011, 05:32 PM   #1
Zero_PSI
Zero_PSI's Avatar
Default My Passport Hard Drive Troubles
Had this pop up. Unsure on what's going on?
Zero_PSI is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2011, 05:44 PM   #2
dredd120
Tyred Mechanic
dredd120's Avatar
Default Re: My Passport Hard Drive Troubles
WD often come standard witha lock on the hard drive, have you used the software disc that come with the hard drive, if you didn't get one, go to WD'd website and download it, I had the same problem but once i install the software it was fine, hope this helps
dredd120 is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2011, 05:45 PM   #3
dredd120
Tyred Mechanic
dredd120's Avatar
Oh and it might need an initial format
Old 02-08-2011, 05:55 PM   #4
Zero_PSI
Zero_PSI's Avatar
It was working. It's not now. Thats what comes up when you plug it in and try to install the device. I tried the unlock and it said it was already unlocked.
Old 03-08-2011, 01:25 PM   #5
StarDeala
StarDeala's Avatar
Are you using the same usb cable that came with it?
Try using another one, preferably of short length.. As these portable drives don't have an external power source, they rely on power through the usb and some longer cables dont supply the drive with enough power.
2005 BA MkII XR6T
18" FPV Rims with Continental GT
Full Leather, Premium Sound, 6sp Manual
StarDeala is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2011, 06:13 PM   #6
z80
You need a minimum service pack level to enable some usb devices to work.
Of course a virus can delete a partition as quick as a flash (pardon the pun)
z80 is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2011, 12:28 AM   #7
TonyBill
TonyBill's Avatar
on that note, if youre using a laptop, plug it into the wall or get a 2-to-1 usb cord
TonyBill is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2011, 01:00 AM   #8
Mechan1k
Mechan1k's Avatar
Had a similar thing .... ended up being a screwed drive.
Lost everything ... which sucked.
Old 13-08-2011, 08:48 AM   #9
Ducati888
Same here. I had one which did the same thing, and that was the end of it. Couldn't access it and it was not worth the money to have a professional extract the data from it.
I took it back and exhanged it for a new one under warranty.
The error occurred when I tried to rip a DVD direct from the DVD drive to the USB HDD and not to the C drive first.
"You can't fight stupid people - there's just too many of them"
Ducati888 is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2011, 08:56 AM   #10
kenz
BOSS Pilot
kenz's Avatar
had a problem like that aswell and havent been able to use it since, even tried the 2-1 usb cord and it didnt work
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2011, 09:13 AM   #11
bigbretty
bigbretty's Avatar
i found the Western Digital drives don't like swapping from computer to computer and like to 'reformat' themselves. Haven't had a problem with the Seagate ones yet. (except for the one inside my HP elite that decided to eat itself)
Current Ride
2009 Falcon XR6t Ute in Mystic
bigbretty is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2011, 02:57 AM   #12
Zero_PSI
Zero_PSI's Avatar
Found the problem. Volume was missing, unsure of what happened there? Created a new simple volume and formatted it to ntfs. Fine now.
Just learnt above drives at tafe lol.
