28-07-2011, 08:02 PM | #1 | ||
I,ve got to burn some heavy timbers, 350 x 350 x 500long. problerbly 4 bits of them, with a few other smaller timbers. they are in a big sand areana, so minimiamal risk of starting a fire else where, and everything is still moist after the rain. I am on acreage. I need the areana . Whos used disesel to aid in burning? I thought i could pour a litre over it and lite it. I think it will need a bit of heat in it to start it. But if it goes wosh-ca, i might not do it.
mick |
28-07-2011, 08:10 PM | #2 | ||
its the fumes that go woosh-ca
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
28-07-2011, 08:19 PM | #3 | ||
Falcon RTV - FG G6ET
Diesel can be used to light a fire as the one you described above.... Just soak a couple of smaller pieces of the material in diesel about 1/2 an hour before you light up. These couple of smaller pieces should be pushed part way under the set of material to be burned.
I'd shove a couple of balled up sheets of newspaper under the whole lot and light the paper first.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
28-07-2011, 09:25 PM | #4 | ||
Fixing Ford's **** ups
Why not use paper, then twigs, then smaller pieces of timber to get the heat into the main bits of timber? Even if you have to create a few holes throughout the main timbers and stuff this stuff into it.
The issue with using diesel or petrol for that matter is, it can catch alight fairly quickly, which then turns rather nasty on the body.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
28-07-2011, 09:38 PM | #5 | ||
Why not just get a couple of packets of those fire lighters, the white slabs. They will burn longer than raw diesel will and very safe to use.
2011 FG XR6 Sedan |
28-07-2011, 09:47 PM | #6 | ||
A good reasonably safe burn mix I've used with driptorches is 3 parts diesel to 1 part petrol. It won't combust explosively like petrol and is perfect for burning piles of timber.
28-07-2011, 10:18 PM | #7 | ||
Chamber is on the money. We use a mix like this all the time on the farm with drip torch's and on bonfires. We have never had an issue with this mix.
28-07-2011, 10:32 PM | #8 | ||
Unintended Perfectionist
We always used diesel to help light the fire in our heaters when i was younger. Never had an issue.....until someone used petrol one day.
BA-FG parts for sale. http://fordforums.com.au/showthread.php?t=11411117 http://s1092.photobucket.com/user/my...?sort=3&page=1 The XR re-erection in the works http://www.fordforums.com.au/showthread.php?t=11386452 |
29-07-2011, 12:10 AM | #9 | ||
Lyminge, Shepway, Kent
And when the fire is going chuck in some empty deodorant cans. Fiddly bits cans go right off too.
29-07-2011, 07:21 AM | #10 | ||
diesel has been used by farmers the world over for generations as its slowish to take off(no big wuuuuummmpppp) like petrol and much safer and slower burning so wood gets some heat in it while diesel burns as it does not evaporate like petrol
Hervey Bay QLD Great trades recently- GILMORE BOSSYONBIKE |
29-07-2011, 07:40 AM | #11 | ||
I am Groot
pfft.....Bear Grylls would just rub a couple of them logs together....
.. McLaren F1 Dick Johnson Racing "Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe |
29-07-2011, 08:10 AM | #12 | |||
Where to next??
29-07-2011, 08:53 AM | #13 | ||||
Back to Le Frenchy
Yes, yes I know it is dangerous and irresponsible. Fun but.
29-07-2011, 09:12 AM | #14 | ||
I have never used petrol to start fires and I have never poured 20 litres on a bonfire to start it and I never cracked my neighbours window over 400 meters away with the resulting explosion.
diesel = good petrol = bad |
29-07-2011, 11:12 AM | #15 | ||
you say your on acres, so why not call up the local RFS / CFA what ever and get them to organsie the whole lot from permit to buring, put on a BBQ and a few drinks and perhaps a donation to the brigade and job done and safe
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
29-07-2011, 06:29 PM | #16 | |||
Thanks for all the great massages, some real good ones and the one with the firestarters was funny but thanks anyway. I could get out there with two sticks and rub them together. But this is piering out of sydney hardour, is really solid stuff (see messerments) its old turpintine. Some funny comments about the mad stuff poeple do around borfires, Ha Ha. I when i was young, we used to throw fibro on the fire, an boom, she she would realy go off. But as i,m new to disiel on fires ,well i just needed to know the buring characterics (big word) . and now i know. thanks all, check out this crazy bonfire vid, its funny and sad all in on vid. http://www.youtube.com/watch?v=1-wnQfy4iwE any further crazy bonfires storys would be good. mick |
29-07-2011, 06:49 PM | #17 | |||||
Captain Malcolm Reynolds
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car) Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla Quote:
29-07-2011, 06:54 PM | #18 | ||
ha ha
you cracked me up. |
29-07-2011, 07:27 PM | #19 | ||
playing in my big shed
diesel is fine to use. slow burning with very little fumes to explode unlike petrol.
as someone said before it would work best if you pour some diesel onto the logs and let it soak in for a while. that way it will keep the fire burning a bit longer giving the wood time to get going. make sure there are some air gaps between the timbers. a bunch of old rags soaked in diesel put under /between the timbers works too. kerosene is good as well. i have seen some nasty after affects of starting fires with petrol. .
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch `10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim. `04 BA RTV tray back, Red, V8 auto, `04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim. `03 BA XLS ute . Acid Rush, factory lpg, auto, `48 TEA20 Grey Ferguson, `62 Willys 6-230 , 4x4 light truck `04 Yamaha TTR 250 |
29-07-2011, 08:34 PM | #20 | ||
Performance moderator
Bail of hay soak in diesel ..
Throw hay biscuts through and around wood .. Light with screwed up paper and your done.. Don't tell Mr B Brown what your doing tho !!!!
30-07-2011, 07:38 AM | #21 | |||
well um I think you dont understand my background or my perfesion but if your gonna flash it up your self do it properly make sure you have water (Good supply) that can reach all the way arround the pile (and I dont mean by shooting it over the top of the pile). if your "on a farm" and I have it all wrong you will have the requirement to do this more than once, so look in to buying a drip torch this is a device you fill with a mix of 60% Diesle & 40% Petrol and light, you light the wick and use it as a torch to light the pile you also need to check the council requirments in terms of permits and alike I would argue that if this is sawn / milled timber its used building materials and you wont be allowd to burn it in a lot of council areras Now its in the middle of the dresarge arena whats it sarrounded by? is it grass? is it kept short or long and over grown? if its the latter, cut it and get rid of the clippings O and if you loose the fire, your liable for the damage it causes go's back to planing it early and a BBQ and a few beers beaing easyer dont it I gotta go now I have to go and work on my farm (um yea its only 10acres but people call less farms ) then after that I have to go to my parrents place as I need to do a few fence repairs at their farm but its hard casue I'm tired becasue we had a few fires last night Actualy that work bis BS I'm just cutting fire wood today
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) Last edited by The Yeti; 30-07-2011 at 07:54 AM. |
30-07-2011, 09:49 AM | #22 | ||
on the way to the RSL
Diesel is a good choice, don't ever use remote control car fuel. I know this somehow.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9" 8.9x@160mph+ |
30-07-2011, 10:13 AM | #23 | ||
thanks yeti, I do take it very seriously ,( buring stuff ) this is why i,m asking. We have had our share of bush fires, but i,m on 90% cleared land.
I,m going to burn today at 3 - 4pm as the heat will go out of the day, and we have had intermitted rain last week and some of this week (S,W, Sydney). so undergrowth should be mosit still. Well i,m on five arces, you got me there, its not a farm as i don,t produce anything, i guess i could say "my property"is that right? however five acreas still needs mantaince, i helped my niehbour and slashed her paddock, i hit rock with the slasher and now the gearbox on the slasher has no oil in it, so that has to be repaired (by me), but that doesn,t stop the weeds from growing ( posions fire weed harmfull/deadly for the horses) and if you can tell me how to how to fix fire weed i would be greatfull!!. theres a couple of things and i,m not even started on my prodjects, found out in the week that the house has termites in it. well my niehbour has tried to get out the fire guys for a burn off, he said do this, do that, put in a fire trail, i graded one in (got 3 tonne tractor stuck on a 40degree day, i was very peed off) , they did all the paper work and more, and guess what, they won,t come out an burn off. well i,ll get throught it. cheers mick Last edited by Pis-ton broke; 30-07-2011 at 10:20 AM. |
30-07-2011, 10:24 AM | #24 | ||
For some reson, cletus has come to my mind a few times in this thread
Completely Stock |
30-07-2011, 10:34 AM | #25 | |||
I know i wouldnt be touching a fire with water that i just lit with diesel
Completely Stock |
30-07-2011, 11:10 AM | #26 | ||
A broad leaf spray will fix 99% of weeds.. Horses will have to be moved for a while.. Cattle can eat what the horses don't eat as they can be fussy. Cleaning up some weeds as well and keeping paddock fresh for horses..
Why would you want water near a fire if there's no fuel nearby ?? Water on wood fire which has been started with diesel is safe to spray.. It's water on diesel itself "in container" which is "bad" news..
30-07-2011, 06:27 PM | #27 | |||
30-07-2011, 06:42 PM | #28 | |||
houses with termites are part of the fun, my joints riddeled with them or was, now back to the "fire guys" you do realise the "fire guys" or RFS as they are knows are volanteers, they get nothing out of it except the satisfaction of helping their comunity, so if you need a HR done let me sugest somthing that worked for our brigade when I was there, come go down on a training night, show an interest, (dont BS telling them you might joine un less you might) talk to the captain expalin what you want to do and what you need the permit for, then offer to put on a BBQ for their members and offer a small donation to the brigade they are always looking for somthing be it little extras the council and state governemt dont give or a training aid they always want money, The last thing my old RFS brigage brought is self was a Lighting tower for the tanker, it ran off the trucks air system to elivate it and had Zenon lights, this thing was sensational at MVA's or house fires and was fully funded by the brigade through donations. that said theres nothing wrong with flashing it up your self if youve taken the proper precations, such as having a good supply of water and having the area arround the fire cleared of vegitation
30-07-2011, 06:51 PM | #29 | |||
I lit the fire today at about 3pm, i poured about four litres of disiel on it. thorugh a match on it and it sterted to burn nice and easy, just what i was after. have just checked it now and those big bit of timber have a bright glow with small flame. the one inch steel bar that is in the timber is red hot. I think it will burn to ash, finger crossed. thanks again for every ones input. mick |
30-07-2011, 07:04 PM | #30 | |||
Completely Stock |
