Old 12-06-2011, 12:56 PM   #1
david lee
Default misfire
when i start my xr6 on cold it has a slight miss untill it warms up. my mechanic told me the computer needed resetting which he did but did not fix the problem.its going back to him.has anyone had this problem. thanks.
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2011, 01:09 PM   #2
Zero_PSI
Zero_PSI's Avatar
Default Re: misfire
My coil-packs are down the crapper at the moment. Mine misses under load though. I have more on order so I'm just waiting.
Coil-packs are a common problem in B-series but I haven't heard anything about AU's. Maybe just have a look for cracking or scaring on the coil.
Zero_PSI is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2011, 01:14 PM   #3
fasty73
fasty73's Avatar
Default Re: misfire
Could be leaking injectors, they leak fuel into the cylinder while the car is turned off, then causing a missfire until it cleans the excess fuel out.
fasty73 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2011, 03:38 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: misfire
oh look its david lee, the guy who asks questions but never returns to shed light on what actually fixed his problem
this is a community not the racv mate
but to answer your question, it will likely be fuel or spark related
how many kays since your last plug/lead/coilpak/fuel filter change?
pcv valve rattle ok?
all vacuum lines seem to be connected?
how many kays on your xr6?
Old 12-06-2011, 05:28 PM   #5
david lee
Default Re: misfire
sorry mate i will fill u in when the problems fixed. it has 150000 ks everything was changed at 120000ks thanks
Old 12-06-2011, 09:40 PM   #6
david lee
Default Re: misfire
thanks mate i will reply when fixed with solution
Old 12-06-2011, 09:46 PM   #7
david lee
Default Re: misfire
thanks i will reply when fixed this week
Old 13-06-2011, 06:55 PM   #8
JC
JC's Avatar
Default Re: misfire
Could be TMap sensor in the manifold sort of under the TB. But doubtful - a miss is usually spark or fuel related. Annoying when the problem is so obvious but the solution can be one of several things.
An easy thing to check is the bolts on the inlet manifold - they tend to come loose, and let random air in causing a misfire type condition.
Ford Performance Club ACT
Old 13-06-2011, 08:05 PM   #9
david lee
Default Re: misfire
thanks its going to the mechanic tomorrow i will let u know what it was.its probably something simple yet so annoying
Old 13-06-2011, 08:22 PM   #10
IGALOP
IGALOP's Avatar
Default Re: misfire
Take it out in the dark leave it running and look under the bonnet for any arcing from the HT leads.
Had the same problem on my 67 Mustang, easy fix if that's what it is.
2000 AU Wagon/ 18 " XR8 Wheels, Duel fuel, White, Tinted windows, only 145000 k's.
2006 BF SR Falcon E-gas Pale Gold 17" Sports wheels, tinted windows, spoilers, etc etc, I40000 k's
1967 Mustang 289 Coupe, White 289 V8, auto, AM/FM/CD player, chromed style steel sports wheels, etc
2003 Hyundai Elantra Sport Hatchback Blue Twin cam 16V 2 litre efi
IGALOP is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2011, 09:37 PM   #11
GK
Walking with God
GK's Avatar
Default Re: misfire
Good advice you've been given.
Is your car on LPG by any chance?
If yes, then I'd say that 75% of backfiring issues can be sorted by plugs, leads or coil pack. If not those items, then you may be running lean on the LPG. If on LPG, then I'd change plugs and get an LPG tune each year.
Hope you get it sorted soon.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 14-06-2011, 07:51 PM   #12
david lee
Default Re: misfire
GK
thanks mate its not on lpg.ive just picked it up from my mechanic who has said not to run it on standard unleaded but run it on premium which has higher octane
Old 14-06-2011, 08:03 PM   #13
david lee
Default Re: misfire
thanks mate i forgot about that trick
