Old 30-05-2011, 02:27 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Excel formula help?
Hoping someone can help, I need a formula to take a number entered into one cell, multiply it by 9 and then put the total into another cell.
Any ideas how to do it?
2024 F150 XLT
Old 30-05-2011, 02:30 PM   #2
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default Re: Excel formula help?
Select the cell you want.
Enter in "=Cell*9" without the ", cell being the cell you want the number entered into (ie: A5, B10, etc etc)
Carless
Old 30-05-2011, 02:35 PM   #3
b2tf
b2tf's Avatar
keep getting the error #NAME?
The number will be entered into C14 then multipled by 9 and placed into C15, so formula should be =C14*9 yeah?
2024 F150 XLT
Old 30-05-2011, 02:36 PM   #4
TheSneakiness
Adapt or perish...
If you don't have a value within C14 then you'll get that error.
The formula needs to be in C15.
Carless
Old 30-05-2011, 02:43 PM   #5
Geez Louise
Awesome
Geez Louise's Avatar
Location: In my own little world..Everyone here knows me :)
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind the scenes things that help the community.
You can put a zero in C14 if you do not have the number but want to set up the formula. Create the formula in C15 =C14*9. It will calculate.
Having said that, it should bring up a zero in C15 if you just put that formula in anyway without any number in C14, unless C14 is a calculation of other cells.
Col
Last edited by Geez Louise; 30-05-2011 at 02:48 PM. Reason: Added more ...just like Excel...HeHe
Geez Louise is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 02:52 PM   #6
b2tf
b2tf's Avatar
Got that one sorted, thanks all. Will advise when I get to next problem!
2024 F150 XLT
Old 30-05-2011, 02:57 PM   #7
b2tf
b2tf's Avatar
Next one:
Need to develop a formula where we have 2 types of chemical being used. One is known as R, the other is NR. If NR is used I want to add 10% to total of job. If the spreadsheet user puts 'NR' into E28, whats the formula to get it to add 10% to the total of the job?
2024 F150 XLT
Old 30-05-2011, 03:11 PM   #8
Tealglow
Waiting
Tealglow's Avatar
=IF(E28="NR",C14*9*1.1,C14*9)
Note that formulas are not case sensitive
1971 XY Fairmont GS Factory 351C & Toploader- Electric Blue & Convo Pros
1984 Bronco XLT 351 C6 4WD - Black/ Silver LPG, 3" Lift, American Racing Wheels
2007 Jeep Wrangler Unlimited CRD Renegade- Black
2009 FG XR6 Vixen
Tealglow is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 03:13 PM   #9
Geez Louise
Awesome
Where are you putting the total of E28?
if into E29 then I think this is 10% =E28*1.1
Old 30-05-2011, 03:24 PM   #10
b2tf
b2tf's Avatar
What it needs to do is add the figures:
E14+E26+E28 (E28 is the 10% one so it needs to know that 'R'=add 0% but 'NR'=add 10%, then add the figure in E30 if there is one in there, and have the total come out at E32.
Make sense?
2024 F150 XLT
Old 30-05-2011, 03:30 PM   #11
TheSneakiness
Adapt or perish...
=(e14+e26)+if(e28="NR",e32*1.1,0)
Give that one a go and see what happens.
Carless
Old 30-05-2011, 03:34 PM   #12
Geez Louise
Awesome
Yep. That makes sense.
in E32 put this: =E14+E26+E28*1.1
There are other more fancy forumulas but that will do what you want it to do. I get lazy when it comes to Excel...
Rapid Axe obviously works with it a lot!
Old 30-05-2011, 03:40 PM   #13
TheSneakiness
Adapt or perish...
Yes, yes I do.
Learned alot through an old job I was in (to the point I programmed in the background using VB to update price files we had in place)
Carless
Old 30-05-2011, 03:42 PM   #14
TheSneakiness
Adapt or perish...
Misread a post.
In my top formula, add +E30 to the end of the bracketed section. It'll add the cell regardless of if a value is present or not.
Carless
Old 30-05-2011, 03:45 PM   #15
Geez Louise
Awesome
Yes...the joys of Excel. I remember back to the old Lotus 123 days. None of this fancy little paperclip wizard to help you!
One thing I hate about Excel...PIVOT TABLES!! It has taken me ages to master them and even then, I think most of the time I fluke it on shear luck
Old 30-05-2011, 03:50 PM   #16
SEZ213
SEZ213's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always puts a good amount of thought into his posts and voices his ideas and opinions in a well thought out and constructive manner. I have certainly seen many threads where his input has been constructive to the topic and overall the forum has benfited f
Haha, Pivot tables are awesome! If there's a day that I want to really 'do my head in' - that's where I start!
I must admit though, I'd rather VB in Access than VB in Excel...
2012 Focus ST
Tangerine Scream
Continually having a battle of wits with unarmed opponents.
Sez
Photo's by Sez
SEZ213 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 07:16 PM   #17
MYVYSS
Back where I belong
MYVYSS's Avatar
if you keep adding to E30 soon enough you will have E85 and in need for a new tune... :P
Regards
Craig
MYVYSS is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 08:18 PM   #18
Stefan
Stefan's Avatar
OH how I love a PIVOT TABLE. Always funny waiting for someone to calculate something for hours even days on end then doing a PIVOT TABLE infront of them in 5 seconds to get the same result.
They will never forget how to do one after that.
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 08:31 PM   #19
GT0132
GT0132's Avatar
Yep I've used spreadsheets for around 24 years , being an accountant has a bit to do with it I guess .....First Lotus 123 then Excel from mid 90's onward.
Also hate pivot tables, probably because I haven't had the time to sit down and learn them and now have a team who do all those mechanical tasks for me, so now don't really want to know.
Best feature in modern spreadsheeting in Excel v the old Lotus is the Undo function (helped me out heaps) ands Goal Seek
2005 BA MK2 FPV GT - 6 SPEED MANUAL , SILHOUETTE, SWISSVAX, SUNROOF, BILSTEIN AND LOVELLS, FACTORY GENUINE 19'S, X-FORCE STAINLESS QUAD CATBACK, ADVANCE HEADERS, 200 CPSI CATS, BLUEPOWER CAI, HERROD BREATHER KIT, 4:11 DIFF RATIO, MAL WOOD OPT 3+ CLUTCH, BILLET SHIFTER, MELLINGS 10227, NOW WITH REVERSE CAMERA/SENSORS, ALPINE SPEAKERS & SUB - CUSTOM TUNED TO 275 RWKW
NOW WITH A NEW ADDITION - 2017 MUSTANG V8 GT FASTBACK - , 6 SPEED AUTO IN PLATINUM WHITE,
GT0132 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 08:49 PM   #20
Geez Louise
Awesome
The amount of times I get a circular reference error because I am being lazy.
Don't get me wrong, Excel is great and I have written more than a few speadsheets with macros etc in my time...but I just don't have the patience for long winded formulas anymore.
Old 30-05-2011, 10:47 PM   #21
FGII-XR6
FGII-XR6's Avatar
looks like you are doing a job quoting system if this is the case you would be better off using access and running a queries to do your calculations this will give you more flexibility and you will have a permanent record of all jobs quoted
[SIGPIC][/SIGPIC]
Rides:
Old 30-05-2011, 11:18 PM   #22
gcg2503
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always adding valued comments,  never involved in any disputes. A credit to this forum.
mmm the joys of excel - vlookups, whatif statements, pivot tables....
Access for the win!
gcg2503 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 11:39 PM   #23
MITCHAY
Probably about the most simple article of the Excel vs Access argument you're going to get.
http://office.microsoft.com/en-us/ac...001042918.aspx
Old 31-05-2011, 12:11 AM   #24
gossy
CLEVO POWERED
gossy's Avatar
I would rather a VB in my tummy.
Sorry to be OT
gossy is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2011, 10:01 AM   #25
b2tf
b2tf's Avatar
Morning all,
latest one for you!
Need to create a formula where a value entered into a cell will be multiplied by 100 e.g. '3' is placed into E19 and will then turn into '300' (3x100=300).
Any ideas on the forumla? This is the last bit I need.
2024 F150 XLT
Old 31-05-2011, 10:12 AM   #26
TheSneakiness
Adapt or perish...
You mean this way???
Type "3" into cell E19
Turns value into 300 automatically?
Don't think it can work that way. You'll need another cell to use as a reference.
Carless
Old 31-05-2011, 10:20 AM   #27
XR6_661
Cane Farmer
XR6_661's Avatar
You can do it by adding custom formatting the cell to show 300...although this is cosmetic, the number in the cell is still 3.
if you want to do it that way, custom format 0"00", apply to the cells you want to multiply...
Other than that, you'd have to stuff around in VB...or as Rapid Axe suggested, you need a cell as a reference.
Hope this helps..
1994 ED XR6T - Cobalt Blue.
2009 FG XR6 - Black.
Originally Posted by Tex
I couldn't give a crap how many are in their family, what gay passtimes they paticipate in, or whether they have a cat, dog or a freaken fish.
Keep your stinking family to yourself god damn it.
XR6_661 is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2011, 11:04 AM   #28
TheSneakiness
Adapt or perish...
What I used to do in that particular case was to have another cell as a reference for the formula to work but then made the text white to blend in and then locked the cell so it couldn't be edited.
Still keeps the page looking clean.
Carless
Old 31-05-2011, 11:21 AM   #29
XR6_661
Cane Farmer
XR6_661's Avatar
I'm sensing a fellow excel guru. Haha.
I have a cup on my desk that has a big red heart followed by 'Excel'
hahaha
Old 31-05-2011, 01:00 PM   #30
b2tf
b2tf's Avatar
hahaha
You're a sick twisted individual.
I've re-hashed the template to get around the cell multiplication issue.
2024 F150 XLT
