Old 06-05-2011, 04:54 PM   #1
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
Default bloody stereo
ok im bloody fed up with this ford wireing...
a few week ago i bought a dvd for the car but it wen sower on me.
so last week i bought a new deck for it.
i go to instal but it wont hold memory every thing s connected i cross referenced everything with wireing diagrams from the car, from the instructions of the stereo and still nothing, oh and i didnt do the dvd instal either a bloody mate did.
i need serious help no crap please, or if you are a stereo wiz come over. pm me..
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2011, 05:00 PM   #2
au11futura
au11futura's Avatar
Default Re: bloody stereo
anyone please before i do damage to it i realy will ditch a spanner at this car............................very soon...................................
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 06-05-2011, 05:01 PM   #3
Jack91
Jack91's Avatar
You sure you connected constant power to the right wire? Thats the only reason it wont hold memory (or the new deck is broken too) (yellow should be constant power).
edit: no memory aint that big of a deal. I had the opposite problem in my first car (had to remember to turn it off) and I lived with that for nearly a year.
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2011, 05:06 PM   #4
au11futura
au11futura's Avatar
yeh it is to the yellow mate but still nothing, its ****ing my right of.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 06-05-2011, 05:13 PM   #5
Jack91
Jack91's Avatar
Well if its wired right then its the deck.
What do you need memory for anyway? Youve already got a clock in the dash.
Old 06-05-2011, 05:14 PM   #6
Day-mow
rexnet
Day-mow's Avatar
Deck sounds dodge or bad connection.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 06-05-2011, 05:24 PM   #7
au11futura
au11futura's Avatar
deck is a brand new pioneer worth over $400 guys how can it be dodge, memory just mabey for radio stations.......................................... .................................................. .................................
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 06-05-2011, 05:26 PM   #8
Jack91
Jack91's Avatar
Ah didnt think of that, fair call.
Ive bought things for thousand of dollars that were dodge.
Can happen.
Maybe worth seeing if theres 12v on the constant wire.
If there isnt, run another wire,
If there is, try another deck.
Simple.
Old 06-05-2011, 05:41 PM   #9
Pis-ton broke
Pis-ton broke's Avatar
I,m no sparky, but i would turn everything off , then get a test lamp and then check at the fuse box for a live wire, if it,s siutable , use it.
Pis-ton broke is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2011, 05:49 PM   #10
robbyj
Rob
robbyj's Avatar
What are your connections like?
did you solder and tape/heat shrink them.
I had a mate whos h/u would turn off after a few minutes of turning on.
Turns out his soldering job was dodgy, i re did and it worked fine.
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2011, 06:22 PM   #11
au11futura
au11futura's Avatar
yeh just did that turns out someone got rid of the orig 12v wire and decided it was no needed.
then i found a 12v relay under my carpet with two wires going from it and into the dash but not connected any where.
refitted it all and bloody hell im stressed. but its working.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 06-05-2011, 06:23 PM   #12
au11futura
au11futura's Avatar
mate i only do solder and heatsink together, nothing else.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 07-05-2011, 03:50 PM   #13
robbyj
Rob
robbyj's Avatar
You never know, there's some very dodgy work out there ;)
Good to hear you fixed it anyway
Old 08-05-2011, 01:04 AM   #14
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
iv never cut and taped into any ford wireing for head units id go buy a Wireing harness for it its simple and everything is color coded
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2011, 03:18 PM   #15
FGII-XR6
FGII-XR6's Avatar
nobody should ever cut and tape if you don't use premade harnesses you should solder and heatshrink anything is a fire risk and just plain stupid
[SIGPIC][/SIGPIC]
Rides:
Old 08-05-2011, 03:32 PM   #16
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
WIRING
there's no E
Old 08-05-2011, 03:52 PM   #17
JC
JC's Avatar
Should we close this thread? Problem solved a few posts ago.
Cut and tape is fine, IF you use the right thermal tape.
Solder and shrink is better.
Cut and crimp works well too.
I tend to cut, crimp, solder and heatshrink.
Ford Performance Club ACT
Old 08-05-2011, 05:35 PM   #18
FGII-XR6
FGII-XR6's Avatar
crimping is acceptable but far from optimal, just twisting the wires and taping them is unsafe and in the event of a fire the insurance can be wiped if they find evidence of this method with power wires ( speaker wires can be just twisted but you can get audio problems). A good solder joint is by far the best method
[SIGPIC][/SIGPIC]
Rides:
