Old 28-04-2011, 08:32 AM   #1
SSD-85
Default More ABS Questions
Good morning all,
The ABS modules in an AU are from what I can gather, are divided into 2 types;
- One for base models (forte, futura, non-ghia faimonts)
- One for upper spec models (Fairlane, Ghia & XR)
Is this correct? Also, I understand theyre not interchangeable, but one thing I need to confirm is that can one be ripped out of say, a Fairlane & put in an XR? Is there any serial number issues/conflicts? Or anything at all that would prevent a changeout from another AU? Cheers for everyones thoughts.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2011, 05:47 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: More ABS Questions
I would have thought that you would be better going by series rather than model as ABS was not std. on some base models. Give FTG wreckers a call they would know either way
Originally Posted by Riksta
Old 28-04-2011, 07:17 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
Here is a bit more info I got from RussW
Re: ABS
In the early series (the ones starting ER there is a different 4 channel model with traction control only for the Fairlane/Ghia and LTD.
In the later series (starting AU2) there is the same but the Fairmont gets it as well.
AU2 2C346 A ABS MODULE, FORTE/FUTURA/"S"/XR, LESS ANTI-SPIN TRACTION SYSTEM
AU2 2C353 A ABS MODULE, FAIRMONT/FAIRLANE/GHIA/LTD, WITH TRACTION CONTROL SYSTEM
ER 2C346 A ABS MODULE, LESS TRACTION CONTROL - 3 CHANNEL, (-) FAIRLANE/LTD/GHIA
ER 2C353 A ABS MODULE, WITH TRACTION CONTROL - 4 CHANNEL, FAIRLANE/GHIA/LTD
Russ
Old 29-04-2011, 01:13 AM   #4
FGII-XR6
FGII-XR6's Avatar
there are traction control and non traction control ABS units in the AU they are not interchangable as the traction one has 4 output pipes ( one per wheel) where the non traction only has 3 output pipes ( the rear brakes share one pipe) the wiring is different too
[SIGPIC][/SIGPIC]
Rides:
Old 30-04-2011, 03:45 PM   #5
SSD-85
Ok thanks fellas,
I just pulled one out of an AU2 XR6 to use in my AU3 XR8. ABS light instantly came on, so im a little puzzled.
Old 30-04-2011, 05:48 PM   #6
SSD-85
its now working, but still failing in the exact way the original one does. So it might be sensors?
Old 30-04-2011, 07:38 PM   #7
Papa Smurf
Papa Smurf's Avatar
The Sensors do wear out rather regularly. Fronts more than rears, from Ford you are looking at $100.00 for the L/H and $103.00 for the R/H.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2011, 08:05 PM   #8
Beer Baron
Id be putting the old ABS module/actuators back in and hooking it up to a scan tool and see what it says.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2014, 05:18 PM   #9
Eva
Hi Guy's
I have a an AU3 sedan 2002 SR model. My Abs light came on the dash but has gone off again ?
I cleaned all the wheel sensors they had heaps of crap on them. The dash lights been off for a month and has come back on. I took the car to Midas and they hooked up a fault finder meter and said that my right front sensor was showing a fault? BUT I did have that replaced 3 years ago and the guy might not have cleared the codes the guy at Midas said.
Midas has cleared my code and said see what happens? Well the light came back on tonight. If you turn the car off and re start it the light goes out ?
Any ideas people? Your help would be much appreciated..
Eva is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2014, 04:53 PM   #10
Casper
Contributing Member
Casper's Avatar
Can someone please post up a picture of where the sensors are on the front and rear? I am having a similar issue with the light intermitently going on and off and would like to clean the sensors to see if it helps.
thanks.
Older, wiser, poorer.
Old 06-02-2014, 10:02 AM   #11
superroo
You can't stop the signal
superroo's Avatar
Shane
Pics taken from the hub replacement guide
http://www.fordforums.com.au/vbporta...?articleid=222
Old 06-02-2014, 03:32 PM   #12
Casper
Contributing Member
Casper's Avatar
Excellent, thanks for that. Now to get the motivation to drag myself under the car again to clean them. The older I get the less comfortable laying under a car gets.
Old 07-02-2014, 07:30 AM   #13
Eva
Hi Casper
My ABS light came back on again! I decided to clean the actual cog that the sensor reads off, which is on the back of the front hubs. My abs light went off the dash and has been off for a week so far with no further problems!
I just used an old tooth brush and brake fluid to clean the teeth on the hub.
I hope this helps?
Old 11-02-2014, 04:33 PM   #14
Casper
Contributing Member
Casper's Avatar
Thanks Eva, I appreciate it.
Mine started coming on after I had the (near new) front rotors skimmed to get rid of a shudder. I suspect either the sensor or the cogs are just loaded with crap. I'll give them a scrub next time I have time and see how it goes.
