Old 19-04-2011, 03:37 PM   #1
Day-mow
rexnet
Day-mow's Avatar
Default power steering pump
so mine has a leak. which obviously is quite bad. because i thought i'd just have a look at it this morning and there was no fluid in there (oh damn)
so i put some fluid in there but the following questions .
1. does this mean my rack is also dead because its been out of fluid for X long.
2. is it worth getting one from a wrecker/2nd hand.
3. is brand new the only way to go.
thanks.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 19-04-2011, 03:49 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: power steering pump
1. I highly doubt it
2. fine if you're selling it
3. See q2
also, are you sure it's the pump and not one of the hoses?
Old 19-04-2011, 03:55 PM   #3
Day-mow
rexnet
Day-mow's Avatar
well no im not. when i took it to get serviced last the mechanic said he wanted to put some new clamps on. so im assuming that its been ruled out and its the actual pump thats leaking.
i shall go investigate. thank you.
Old 19-04-2011, 04:58 PM   #4
Day-mow
rexnet
Day-mow's Avatar
i had a look. and took a photo. its all tight. the leak/gush/weep seems to be coming from the lower bolt.
that being said. the above bolt is a bracket which i dont have attached to anything because i have extractors. and it lost its mount point (or i lost the bolt haha) and it was a bit loose. does this effect the seal of the pump res?
Old 19-04-2011, 10:08 PM   #5
Stav
Smile
Stav's Avatar
Yes I was told by a power steering place my pump hoses needed changing for a few hundred dollars. I discovered that all it was is a rubber o ring that seals where the the tup of the hose alloy coupling seals against the pump. The oring cost me 3 dollars two years back. It looks like this is the likely cause
Old 20-04-2011, 09:11 AM   #6
Day-mow
rexnet
Day-mow's Avatar
You have made my day. Thank you =]
Old 20-04-2011, 12:51 PM   #7
david lee
i had the same problem it was a leaking top hose which leaked in to alternator causing it to fail as well. it is a common fault with the hose
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2011, 03:55 PM   #8
blueoval
Critical Thinker
blueoval's Avatar
Another vote for the o-ring. I had mine done recently. Happens after a while on AU's. Forgot how much it cost to fix mine, but it wasnt all that much. Had the p/s unit resprayed black while it was out.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2011, 07:32 PM   #9
Day-mow
rexnet
Day-mow's Avatar
Well I went to ford after talking to the house loans deparment at savings and loans and it only cost me $4.40!!!!!! That's unherd of..
But they don't have any instock and I'll get it tomorrow. Dads coming over tonight tho to have at look at it with me. But I'd much prefer to spend say $5. And find out it still leaks instead of 100+ and it still leak. Fair stoked fellas thanks again!!
Old 20-04-2011, 07:46 PM   #10
Stav
Smile
Stav's Avatar
Talking Re: power steering pump
Haggle them on the price. See what happens
Old 21-04-2011, 03:40 PM   #11
blueoval
Critical Thinker
blueoval's Avatar
Ask them if they can offer pensioner discount.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 21-04-2011, 09:06 PM   #12
Day-mow
rexnet
Day-mow's Avatar
speak for your self shav.
im 21
swapped the seal. looks to not be leaking. stoked!
Old 22-04-2011, 06:05 PM   #13
blueoval
Critical Thinker
blueoval's Avatar
Lol. At least its now sorted.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
