Old 28-03-2011, 05:44 PM   #1
baz
Default AU trailer wireing
Does anyone know which colour goes with what in the boot.
I have a au fairmont ghia, its got a plug inside the boot for a trailer but i want to splice in my trailer wires to just before the plug. Thanks
baz is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2011, 05:49 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: AU trailer wireing
http://www.campertrailers.org/traile...ng_diagram.htm
Originally Posted by Riksta
Old 28-03-2011, 05:56 PM   #3
baz
Thanks but I know that I need to know what colour wire in the boot that goes to the plug matches up with the trailer colours
Old 28-03-2011, 06:01 PM   #4
Whoosha
AU DIE HARD
Whoosha's Avatar
If your splicing the wire use a test light on each individual wire as you go. just turn the lights ,blinker ext. on 1 at a time and match it to the chart
Or undo the cover on the plug in the boot and match it to the trailer plug
Old 28-03-2011, 06:37 PM   #5
FGII-XR6
FGII-XR6's Avatar
or buy this it's just plug in and away you go http://cgi.ebay.com.au/New-AU-BA-Fal...item3f0894ba1d the advantage of this for most people is a better connection as most home trailer wiring jobs I've seen have been just twist and tape . in the long run this far from ideal
[SIGPIC][/SIGPIC]
Rides:
Old 29-03-2011, 09:29 PM   #6
Jimmyd
Fitted one of these to the my AU Fairmont Ghia - well worth the 42 bucks (inc postage)
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2011, 09:25 AM   #7
baz
Is the hole pre drilled to put the plug through in the boot?
Old 30-03-2011, 01:49 PM   #8
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
Yep it should be as I removed one from my old car and fitted to my silver one
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2011, 02:27 PM   #9
baz
I removed the plastic cover where the plug is but didn't see a hole,is it behind the number plate?
Old 30-03-2011, 06:04 PM   #10
Jimmyd
No, floor of boot rear corner on drivers side - need to run the harness up behind the bumper.
Old 30-03-2011, 06:55 PM   #11
POELWYK
POELWYK's Avatar
yeah its like a rubber grommet thingo with the wires going though it
2001 AU Falcon
Old 30-03-2011, 07:30 PM   #12
baz
Thanks guys for all your help
