Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 21-03-2011, 09:50 PM   #1
IXR08
IXR08's Avatar
Default Kenne Bell on 5.0
Guys just curious to how long till you gents have some of your own data from a kenne bell being fitted to the 5.0 with one of your own produced kits?
http://www.youtube.com/watch?v=Q9-OmkFKRnY
- TTG 16psi (Plazmaman Frount Mount, high flow cat 42lb injectors)
- BF F6 (530rwkw)
- xr8 ute kenne bell 2.6 (sold)
IXR08 is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2011, 09:20 AM   #2
Bluepower
KenneBell Australia
Bluepower's Avatar
Default Re: Kenne Bell on 5.0
We already have! When its ready for public release, it will be posted on here and on the website.
Chris
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2011, 10:08 AM   #3
IXR08
IXR08's Avatar
I figured you must be getting close.... look forward to reading about it.....
- BF F6 (530rwkw)
Old 22-03-2011, 11:11 AM   #4
StealthAu
How complicated would swapping the 260 in my BF for a coyote be?
Old 22-03-2011, 11:18 AM   #5
Theo@BluePower
Bluepower
Theo@BluePower's Avatar
I wouldn't think it would be too bad, the firing order is different, so a little wiring would be in order, most of it is a bolt straight in job.
Bluepower website
47 Cooper Street Campbellfield Vic
03 9305 3000
Theo@BluePower is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2011, 11:26 AM   #6
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
You can get a wiring harness on the NA 5.0 that should help.
Theo, you guys got any clients looking at the 5.0 NA conversion? Is this something that you may offer in the future?
  • 2023 Mitsubishi Triton
  • 1973 ZF Ford Fairlane
Old 22-03-2011, 11:49 AM   #7
StealthAu
So would it be worth looking at this path if considering an engine swap along with a 2.8LC? What I'm really asking is would their be any advantages to going with the engine/blower combo over the setup you guys did on Tex's car? Main interest is if there is much options as far as aftermarket gear such as cams and extractors and how controlling the VCT with the BF ECU would go.
Old 22-03-2011, 02:43 PM   #8
Theo@BluePower
Bluepower
The US ECM as manage 4 VCT.. the Aust ECU can only run 2 VCT.. so if you were to put a 5.0 in you wont be able to get the 307 as you wont be able to move cams.. and the cam spec's for the Aust cars are different to US 5.0..
It unchartered waters but i am sure we will find out soon, as the few Corba/Kit car workshops are already asking questions from us on tuning ..
Bluepower website
03 9305 3000
Old 22-03-2011, 04:32 PM   #9
StealthAu
If the BF ecu can manage 2 x VCT, wouldn't it be possible to run the 2 intake cames off the 1 channel and the 2 exhaust cams off the other? I don't really understand what advantages could be had running the 2 intake cams independently and having the exhaust cams fixed timing, but I really don't know bugger all about VCT.
Old 22-03-2011, 04:49 PM   #10
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
Add to that, would the new ECU coming for FG2 (used in the current Tezza) be able to handle it? Guess that depends if its compatible to the rest of the B series or FG components?
