13-02-2011, 06:09 PM | #1 | ||
Hey,
(forgive my ignorance) So tomorrow I'm going to pick up a 75-77 Chrysler Sigma. Now I assume that will run on straight 91 octane ULP Or is it old enough to need an additive.
HIS THUNDER 2004 BA XR8 Blueprint Mods: Quad Exhaust, Hi-Flow Air filter, BFtiming chain tensioners, Billet Oil pump gears stage 2 shift kit, riding on G6ET 18's HERS FLASH BA MKII XR6 Turbo Phantom Purple Typhoon front end Parking your ford after a long day of being Awesome
http://www.facebook.com/pages/Parkin...37774932974038 |
13-02-2011, 06:10 PM | #2 | ||
Cruising...
Yes it will run on 91, yes you need the additive to avoid valve head recession and other things that will shorten the life of the motor.
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 |
13-02-2011, 06:35 PM | #3 | ||
98 Ron maybe better (or worse). Experiment and see. My 1963 seems to like 98 Ron best while my 1980 lancer runs best on PULP (premium unleaded). Even different brands can perform differently and sometimes a 50:50 mix of Rons (swapping every second fill) can work best. I would ask at http://www.sigma-galant.com in the Sigma forum what others with similar cars or the identical engine find best. I also use an upper cylinder head lubricant in both (Red-X) and my 1980 LC Lancer that I have had since new (over 300,000 km) is still running fine and has never had its head off.
regards Blue |
13-02-2011, 06:54 PM | #4 | ||
The leaded fuel available back in the '70's and early '80's was mainly 'Super' which was 97 octane minimum, so using BP ultimate (98 RON) is equivalent as far as octane rating is concerned (to avoid pinging). But since Ultimate is unleaded, it also needs the valve seat lubricant to avoid recession as mentioned.
For my pre unleaded cars I have used BP Ultimate with Penrite 'Valve Shield' additive available from Autobarn etc ever since Ultimate became available. The required amount of additive is poured into the fuel tank before filling with fuel, so it mixes in the tank as you fill up. |
13-02-2011, 06:59 PM | #5 | ||
Had Rep of GT-HO. Legit.
Dont use the 9 crap. Best to use 98 with lead additive.
I use BP Ultimate with Nulon Lead additive and my XC doesnt skip a beat. Put 91 in and even with lead additive, it after fires when i turn the car off.
I'm back! Finally. |
13-02-2011, 07:12 PM | #6 | ||
you dont need to add anything to it...most jap cars with alloy heads built in the 70s were built to run on unleaded..we were way behind when it came to switch to unleaded..
you could even run 91 or E10.. if it pings back the timming off a bit edit. so i dont get flamed http://www.aip.com.au/health/lead_guide.htm Last edited by Zedjay; 13-02-2011 at 07:26 PM. |
13-02-2011, 09:32 PM | #7 | ||
Its a sigma put in whatever you want!
I wouldn't bother about the additive unless your keeping the car for years and years..... it doesn't destroy the valves that quickly |
13-02-2011, 09:46 PM | #8 | ||
I wont be putting, 98 in it thats for sure, the idea is to use it as a daily, and IF Idecide to keep it for longer than a year the chances of it staying a 4 cylinder will be very slim
XR6 Turbo motors are getting cheap these days
13-02-2011, 09:47 PM | #9 | ||
[QUOTE=Zedjay]you dont need to add anything to it...most jap cars with alloy heads built in the 70s were built to run on unleaded..we were way behind when it came to switch to unleaded..
you could even run 91 or E10.. if it pings back the timming off a bit + 1 ^
"You can't fight stupid people - there's just too many of them.The internet: Access to all the world's idiots |
13-02-2011, 09:51 PM | #10 | ||
I now have some light reading which suggests that its fine to run on regular 91
13-02-2011, 09:59 PM | #11 | ||
Forget my post
I totally read Chrysler Valient in your original post cause i was talking to my mate about one at the time. Then when i saw in others posts "Jap car" and "4 cyl" i was liek waaaiiiit a second! >.<
13-02-2011, 10:05 PM | #12 | ||
I'm still alive
My paddock bomb which is an 86 needs lead additive cause it ran on leaded fuel. I would assume the Sigma will need the same?
2006 BF XR6 Winter White Visual -Lowered on SSSL's -5000k Headlight conversion -DJR Bobtail -Darkest legal tint -Tinted taillights Audio -Ford Premium Sound -Pioneer 1000W 12'' Sub -Pioneer Class D Digital 800W Amp Performance -Custom Cold Air Intake Build Thread http://fordforums.com.au/showthread.php?t=11344773 |
13-02-2011, 11:07 PM | #13 | |||
Pity the fool
Talk about needing 'additives' is complete crap As Zedjay said they were designed for it looooong before our poxy restrictions kicked in. In the US it was mandated from 1976!
Fords I own or have owned: 1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD Proud to buy Australian and support Ford Australia through thick and thin |
14-02-2011, 12:10 AM | #14 | |||
see http://www.jsae.or.jp/autotech/data_e/9-9e.html Other smog and ULP devices on non OZ cars included more complex fuel vapour recirculation systems and more sophisicated EGR systems.
regards Blue Last edited by aussiblue; 14-02-2011 at 12:29 AM. |
14-02-2011, 12:14 AM | #15 | ||
regards Blue |
14-02-2011, 01:45 AM | #16 | |||
edit; sorry i ment to quote the post above the one i quoted |
14-02-2011, 12:05 PM | #17 | ||
Sigma had an alloy head that came with hardened valve seats fitted from factory. No additive is required.
As its a daily flog box - if she pings on 91 just retard the ignition timing a little until it stops pinging. |
