as the title says , i had my instrument cluster out and every now and then there is an audiable 3 slow beeps from the cluster , nothing i've heard before , seems to to happen when it is hot weather. i've recently had new brake pads fitted , disc machined , new steering pump & an oil leak from behind the pulley tensioner fixed.
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
Over heating ?
AU XLS. |
nah temp gauge stays between the n & the o on temp gauge even when stinking hot , always has. ?
Walking with God
It'll probably be the DTE warning.
It beeps at 80kms to empty, then again at 40 and perhaps even 20 IIRC. Cheers, GK
ROCKING THE EL FUTURA
either that or you have the speed alert on... chech for a little s symbol in the cluster were the odometre is.
or there is a fax comming through.................
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
yeah mine beeps 3 times when i hit them DTE klms,
nah its a different beep to the DTE . and not speed alert as it has done it whilst sitting still. it goes beeeep , beeeep , beeeep. like its ****ed off. only started when i removed instrument cluster to change some globes, and i've had the cluster out that many times before , never happened
hmmm not a fax comming through???
i thin they beep when they are on diag mode aswell.
is that a bad thing , or will it sort itself out , thinking of resetting ecu ?
does your airbag light work theyy will beep if it is not working.
Ian
Acid rush txr6,5.1 surround sound,350 rwkw's,major interior trim work. |
#12 | ||
Washer bottle empty?
Mercury Silver 03 BA GT-P Tremec TR3650 Number 534 Herrod 4 into ones, Manta Exhaust, CAI, K&N Filter, Mellings oil pump, 19" FPV alloys, Bilsteins, Kings, tuned by Autotech, 272rwkw ![]() RIP Fish 15/1/73 - 9/2/19
yeah filled the washer bottle . airbag light goes off after a few seconds as per normal . as i said it has only happened when it has been hot weather
#14 | ||
Walking with God
Hmmm, not sure what that'll be then.
Maybe it is the fax playing up! LOL! GK
#15 | |||
but cant remember how to change it back.. but yeh try to reset the ecu mate disconect the bat for about 3 mins.
#16 | ||
#17 | ||
5.0 means business
check washer bottle?
Windsor V8 Enthusiast! Turbo Barra Lover! ![]() |
#18 | ||
the beeps are actually three lots of 5 beeps , i had to correct
#19 | ||
meh.
![]() Join Date: Jul 2010
does your airbag light, light up when you turn the key to accessories?
usually, if there is a fault in the airbag system (like when i have the airbag and sensors disconnected in the EF and AU) it will go beeeeeep beeeeeep beeeeeep.... dte is 3 very short beeps in a series of four groups edit: my **** up.... its already listed above... stupid iPwn 3Gs
#20 | ||
Low Oil Pressure - explains why it only (or mostly) happens when it's really hot. Also explains why it happens when stationary with IGN on and engine at idle.
#21 | ||
![]() Join Date: Dec 2004
Agreed T3Man, it sounds like the low oil pressure warning to me.
Hot weather and idle at a red light can do it if the oil changes are not kept up to date.
#22 | ||
just had an oil change ,which is done every 10k , it will make the 3 sets of 5 beeps then stop . if i stop the car then start it again it will do it again.
#23 | ||
Regardless of whether it's just had an oil change or whatever; the fact that it is emitting 5 beeps indicates low oil pressure. Now it may just be the switch. You want to hope so.
#24 | ||
would low oil pressure make the engine abit noisey , as the engine is quiet . eg- no tappy sound
#25 | ||
Walking with God
Try changing the switch as has been suggested.
Cheap and pretty easy to do. If the problem still persists, you know it's either the viscosity of the oil (probably not) or another more serious problem. All the best with it. GK
#26 | ||
my oil pressure switch is disconnected and it still makes the beeps
#27 | ||
Walking with God
I would have thought that having the switch disconnected would make it beep the whole time!
GK
#28 | ||
i had a t3 cluster fitted into my forte , and they couldnt get the oil gauge to work so i disconnected it , and it has only started beeping , when i had the cluster out to change some globes , last week
#29 | |||
Walking with God
However, if the oil gauge is not working and is disconected, the ecu probably thinks your oil pressure is kaput! In my S1 wagon, I fitted a Tickford XR cluster. The temp gauge wasn't working so the ecu kept thinking the car was overheating and putting the auto into Limp Home Mode. You may very well have a similar issue to what I did. The pod that runs the gauge was crook and another had to be sourced from another high series cluster. When it was changed over, all was good. A few years (about 3) after I first bought the cluster, it was finally fitted. GK
#30 | ||
+1 Check washer bottle.
****el's drive Rotaries, Four in-line is a waste of time, Six in-a-row just won't go, If you really want something great, drive a great big Ford V8! God made Holden's to keep w*****'s out of Ford's, and yes I'd rather push my Ford than drive a Holden! |
