Old 21-09-2010, 09:21 PM   #1
asbro
Default indicaters come on when car off
Hello, i'm stumped, got a 99 au, have a intermittant fault, sometimes when i start car, wipers turn on also, when i turn car off, hazards come on, i then turn key to when all lights are on it stops, also when i start car hazards stay on for 3seconds, i have no remotes, ive disconeected battery 3 times overnite, problem goes away for a day. Any ideas?
asbro is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2010, 09:43 PM   #2
frd906
could be the smart lock playing up, or the connections behind the fuse panals are losse
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2010, 10:04 PM   #3
asbro
cheers will have a look, whats the guts if smart lock playing up? Thanks
Old 21-09-2010, 10:11 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
that's really cool man
yeah we had a cab (99 AU1 also) that had it's smartlock go spastik (damn that's a dog, smartshield is about 4251234 times better) and it got taken away on a flatbed it was berko.
Old 21-09-2010, 10:26 PM   #5
asbro
Do you know how much for a smartlock to get fixed, i presume its a ford service job, cheers
Old 21-09-2010, 10:41 PM   #6
fourl6
AU Falcon Man
fourl6's Avatar
sound more like a problem with the indicator/wiper stalk assembly to me, you should be able to pick one up from a wreckers pretty cheap , if you know how to remove and refit the steering wheel its not much harder. after removing the steering wheel its 3 screws and 1 pug to replace. maybe un click the clock spring first.
iv never heard of smartlock causing wiper issues and you haven't mentioned any problems with you door locks...
Cheers Cam
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2010, 11:39 PM   #7
asbro
the doors do click in and out for a few seconds after the indicaters flash, both indicaters flash at the same time, hmmm, cheers for all the input
Old 22-09-2010, 05:48 PM   #8
asbro
Ford believe its a bcm, is that the thing that has stuff to do with smart locks?
Looking at $800 to a $1000 to fix, hmmmm what to do?
Old 22-09-2010, 05:57 PM   #9
fourl6
AU Falcon Man
fourl6's Avatar
you could get one from a wreckers cheaper, but would then have to get ford to program your keys to it...
i fitted a whole AU fairmont dash for $250... just another option...
Was
Old 25-09-2010, 08:42 PM   #10
asbro
well took the car to ford, plugged into computer and nothing shows up, hmm, fingers crossed the phantoms gone away
Old 25-09-2010, 08:51 PM   #11
frd906
Could be the bcm, just go to the wreckers and get one
Old 26-09-2010, 05:57 PM   #12
asbro
in regards to bcm, does ford still have to put on computer, reprogramme?
Old 30-09-2010, 01:21 PM   #13
asbro
heres an update, went to wreckers, pulled out 2 bcms, what a waste of time, during 99 ford changed the bcm on au 3 times, got the wrong 1, and ford have to programme bcm in, to make things worse, ford dont sell bcms, hmmm gota do the lucky dips at the wreckers
Old 30-09-2010, 01:25 PM   #14
frd906
just get all the info off your bcm and take it in with you to match the right one.
