Hello All,
I am looking for a quick easy way to raise my car suspension 35mm on the rear and 17 mm on the front so I can pass inspection for SA registration. Presently the vehicle is registered in Vic and it seems it does not matter. The ute has coils up front and leaf springs at the rear. Just need it to get through an inspection, and then revert to normal, not sure if I can get away with just changing the shocks or do I need all new suspension gea. Perhaps second hand components will get me through. Any ideas are welcome
I hooked up my accelerator pedal in my car to my brake lights. I hit the gas, people behind me stop, and I'm gone. ~Steven Wright |
Fixing Ford's **** ups
Second hand suspension is about the only way. Oh and the cheapest too
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
![]() Join Date: Jan 2005
Couple of bags of cement in the back? No wait, that would lower it.
![]() SVO's on the money - you need to replace springs.
I've got a similer problem. I've been looking into adjustable suspension like koni yellows. Relatively expensive but allows you to go up and down ( if you ever have to go over pits again).
Weekend AUII xr8 Daily 1988 F250 460 Hers Eb xr8 |
#5 | |||
Otherwise, just get the rears reset. Or, for the price, have a look at these: http://cgi.ebay.com.au/Ford-Falcon-A...item335d95f9a4 I fitted a set of those to my ute 2 days ago, and it's 38cm from the center of the wheel to the top of the wheel arch. I have stock XR springs on the front, and the back now sits slightly higher than the front.
Current Rides: 2000 AU 5L XLS ute; 1970 Mustang project |
Or you could fit some of these under the rear:
http://www.heasmans.com.au/polyair/product/index.html
#7 | |||
Former BTIKD
![]() Join Date: Mar 2005
#8 | |||
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
Well thanks all for the advice. quick an easy solution was a set of 2nd hand springs from the wreckers and in they went. The back is a little higher than I would have liked but a set of intermediates down the track will resolve this. Besides I can always put the old ones in.
