Old 06-07-2010, 04:52 PM   #1
BradZ
I'm still alive
BradZ's Avatar
Default Mk2 Escort Starter Not Throwing In.
Having problems with my starter motor. When you push the button to start, most of the time it just whirrs and wont throw in. I keep pushing it and eventually it grabs and cranks. When it does grab the engine turns over fine.
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-5000k Headlight conversion
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
-Pioneer 1000W 12'' Sub
-Pioneer Class D Digital 800W Amp
Performance
-Custom Cold Air Intake
Build Thread http://fordforums.com.au/showthread.php?t=11344773
BradZ is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2010, 07:16 AM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
Bradz
there are 2 sizes of starters that suit the pinto, escort & cortina, the escort ones are from experience in the rally car very fragile and tempermental.
The most simple & cheapest option is to stick a cortina one in
they are larger in size and will require either lifting / tilting the motor and or removing the passenger side engine mount to get it it
(when you stick them side by side it is easy to pick as there is a noticable size difference)
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2010, 07:55 PM   #3
Les
Mk2 Racer
Les's Avatar
Brad, I've had the same problem but was able to take the starter off and clean the bendix shaft. It gets a bit dirty and won't let the cog slide forward. Puzzle is right when he says the left engine mount needs to come off to get the **blessed thing ** out. I was lucky enough to have a few spares and there are two types, one a bit smaller but no probs fitting.
Cheers and good luck.
Les
Les is offline   Reply With Quote Multi-Quote with this Post
