01-06-2010, 10:38 AM | #1 | ||
v8snerlo
Guys,
I have had a look around and unless I'm doing something wrong, I can't see any advice on a how to change the radiator fluid in an AU 6. Is there one that someone can pass onto me? I'm taking my girlfriends AU 6 cylinder forte to the snow in a couple of months time and I want to do a radiator flush prior to going down to ensure that the fluid doesn't freeze up. If anyone can let me know if it is a do it yourself thing then I would be greatly appreciated. Any other checks that you think might be needed would be appreciated as well. Thanks a lot. Leon
2013 SZ Territory Titanium AWD TDCi - Winter White, Leather, DVD, Full tow pack | Mods => interior Light LED Conversion & LED Blinker/DRL conversion 2008 VW Passat R36 Wagon - Black, Leather, DSG, 18" Omanyt, Sunroof, LED Mods = Best and quickest car I've owned Previous Rides 2006 VW Jetta 2.0L FSI Turbo 2000 AUII XR8 (200kw) - Miss my old girl 1996 EF Falcon Gli - Rare manual 1988 Mazda 626 Hatch 1982 Mazda 626 Sedan |
01-06-2010, 10:55 AM | #2 | ||
Formally kotevski22
Remove bottom radiator hose flush,If you want to do a engine and radiator remove thermostat and bottom hose flush engine and radiator fill up with water warm engine and flush again, re fit add 50 water and 50 coolant.
01-06-2010, 10:56 AM | #3 | |||
I used lectric washing soda diluted in warm water, fill the radiator up with that, theres a process i can't remember right now, ill have to dig it up
found it..straight from InfernoSR in this thread Quote:
01-06-2010, 08:58 PM | #4 | |||
The only thing u'll see!!
What happens to the soda that remains inside the block, or worse yet due to tempreture fluctuations inside the cooling system solidifys inside the radiator. Unfortunatly one can never completly clean out the system, just dillute the coolant that remains, therfore i recommend taking the car to a repitable workshop that has a flush machine and using manufactures specified coolant. Remember the vehicle when new has to last the warranty period in all climatic conditions, without issues, so they wont skimp on items such as this, to save on potential warranty claims. Good luck.... |
01-06-2010, 09:26 PM | #5 | ||
Giddy up.
Which remind's me, I must flush mine some day soon aswell, just another job to add to the list, lol.
01-06-2010, 09:50 PM | #6 | ||
JCTO AUII Falcon
Just thought I would add my 2cents worth.....I had to replae my rad last year. Luckily for me a place I used to work had an account at Adrad and they ordered it for me and I just picked it up and paid cash.......got the copper and brass for $168.00. I then just got a local rad specialist to do the change over and flush...he filled the unit with adrad coolant and it has been fantastic over the last hot summer here in perth......even on hot days with a/c running and just sitting idling for an hour (dont ask)...he only charged $105.00 to do it all...champion.
01-06-2010, 10:49 PM | #7 | ||
Check bottom passenger side of radiator under the air intake bit for a plug/tap/bolt that can be undone to drain the water out.
Easier than removing hoses. |
13-08-2011, 12:00 PM | #8 | |||
The welch plug that I have to replace is still leaking so there's water in the system... I even added 2L to the surge tank then ran the engine for 30 sec... nothing more coming out of the plug outlet??? What am I missing? Is there an extra rubber plug in there that I can't see? I can give the corroded welch plug a whack and drain it that way, but I'd rather do it the right way! |
13-08-2011, 06:45 PM | #9 | ||
dont forget to check the belt to
14-08-2011, 12:44 AM | #10 | |||
rexnet
that doesn't sound good. do you have a gregories manual? im pretty sure they have a basic flushing procedure in that. |
14-08-2011, 12:01 PM | #11 | |||
Sales Representative
Solidification within the radiator i have seen only the once, and that was caused by simply using way to much coolant (it turns to a hard gel).
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
16-08-2011, 09:32 PM | #12 | ||
Highway Taxi
The best bet is to take it out of the car. I just replaced mine and it is not a hard job. I put the radiator cleaner in the radiator whilst it was in the car and wulah..the radiator started leaking. The only thing holding it together was gunk, it runs a lot cooler now and I replaced all the hoses whilst I was at it. The radiator was only about $100. Make sure you NEVER mix coolant use the same otherwise it foams and is RS.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
18-08-2011, 12:33 PM | #13 | |||
This is all that came out in the few minutes I had the plug off!!! Removed the lower hose and it all came flooding out... it was definitely full... Is that brown gunk coolant or rust mud? I guess it's all settled at the bottom and blocked the drain plug? (but luckily not the lower hose) Once it's cooled a bit I'm going to stick a garden hose at various ports to give the system a good flush, might try removing the drain cap again and squirting some water in there, see if it frees up... |
18-08-2011, 05:19 PM | #14 | ||
No luck with clearing the blockage at the drainage port. I managed to squirt a bit in there and get the water running out to be clear, but it seems to be blocked further in still.
I've been running with the climate control set to 32C and have noticed that the surge tank contents now look a bit cloudy (was a temporary clean tap water fill). Hopefully this is gunk coming from the heater core. Flushing is fun, I got absolutely soaked. |
08-02-2012, 07:56 PM | #15 | ||
Might do mine again, and flush out that drainage plug area. I usually do (remove hoses)/thermostat, but that plug has got me interested again
10-06-2017, 06:51 PM | #16 | ||
Yep ... BOOSTED
Im doing our AU2 this week (if it ever stops raining).
I will try all the above ideas. I will remove the drain plug first to see whats happening, then proceed as I normally would. With 255,000km on the clock, she needs my undivided attention. Also replacing the thermostat while we are there. Might bleach the reserviour too. Going to do an engine flush with some wynns stuff. And after that, she is getting a redback exhaust, headers to tail.
Daily Driver - 2000 - AU2
(April Fools Day Build) |
