The Monty
Hey i was just wounering,
how hard is it to put in an IRS set up if the car is Live Axle? Details: COMPLETE FROM DISC TO DISC IN ITS CRADLE WITH SPRINGS AND SHOCKERS COME OUT OF AU GHIA 2000 MODEL RATIO: 3.45:1 AND IT IS LSD NO OIL LEAKS. Cheers Brad` |
good question brad, i will be interested to see if the mounting points are there on a live axle car.
You have to re-build the entire rear section of the floor pan as the mounts are completely different. If you are a panel beater and have free access to all the equipment and have the free time to do it then go ahead. Otherwise it is more cost effective to sell your car and buy one with IRS already fitted.
PEPI69
I asked the same question a couple of weeks ago - "IRS CONVERSION" - expensive and a lot of work.....my query of this was because my suspension set up raises wheels of the ground when going up a driveway at an angle and I was getting tired of being in a 'diagonal see-saw' when this happened......I can live with it though - modding cars has certain draw backs - main one I found is the 'creature comforts' such as handling better....increase of NVH and ride etc.
aims to please................. |
Their is aguy who did this on the EL/Ef as well as converting to VST but it looked like a major job, He has a web site so you can see the job.
Most in the section and some one will shoot you a link.
Au Falcon Ute S2 2001 Lowered on Kings with Bilistien Shocks all round 2.5inch cat back K&N Panel Filter FG XR6 17" Rims 245/45-17 tyres XR6T Snorkle BA front Caliper Conversion 300mm With Bendix Heavy Duty Pads Tow bar Transmission Cooler |
All I can say, currently having no rear end in my XR8, is that you do not want to be doing this yourself. The IRS weighs a ton, and you need alot of room to work with to even get it out from under the car.
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
