Old 03-02-2010, 12:40 PM   #1
Dennis8
Dennis8's Avatar
Default V8 into Capri in VIC?
Hi guys,
I did a search but could not find a firm answer, maybe someone here can help or point me in the right direction.
I am currently in Sydney but am looking to move to Vic in about 3 years.
A mate of mine has a capri with all the hard stuff done (Brakes, 9in, C4, Chassis kit and very mild 302), this car is now all but useless here in NSW but seeing as I am moving, is it still possible to get this car engineered in Victoria when I move? (assuming the laws don't change in that time).
I have always wanted a Capri but prices are stupid now, this way I can work on it slowly and build it the way I want (will convert to manual).
Any help/advice muchly appreciated, please no guessing, I'm after firm confirmation, maybe a contact number for a good Engineer in Vic so I can call to discuss, or is there a Vic Roads technical line I can call for confirmation?
Thanks heaps
Dennis
Dennis8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 05:58 PM   #2
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
From the Vicroads website have a look at the Vehicle Standards Information bulletins VSI No. 8 - Modification Guide to start with.
You have to use a Vicroads-approved engineer - have a look [rul=http://www.vicroads.vic.gov.au/Home/SafetyAndRules/SaferVehicles/LicensedVehicleTesters/VehicleAssessmentSignatoryScheme.htm]here[/url]
Old 03-02-2010, 08:25 PM   #3
whooligan
whooligan's Avatar
I think 302 is still fine as imported factory Peranas set a precedence. Hard thing is finding an engineer willing to put his name on the certificate for a reasonable amount.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 09:25 PM   #4
cosworthfreak
cosworthfreak's Avatar
Hi Dennis,
Going by the info in the link below, it seems a 302 Capri is still possible in NSW, unless this guideline is under review or due to be changed:
http://www.rta.nsw.gov.au/registrati...s_nov_2007.pdf
There a few people I know of in NSW that are still working to this, so hopefully it's all still ok.
Jamie
cosworthfreak is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2010, 08:42 AM   #5
Dennis8
Dennis8's Avatar
thanks for the replies, I may just start contacting a few engineers to see if its worth it. I really want to pick up this car but it will be a few years before I have it finished (wife, 2 kids, house and all...)
Hopefully get it done before they crack down any harder.
If I do get it, I will be sure to start up a project thread for it.
Cheers Fellas.
Old 22-02-2010, 09:09 PM   #6
laven321
hey mate im currently doing a 302 into a capri and have been told by an engineer in nsw that it is still possible to do mine was an original v6 though not sure if it helps it should be ok as long as it is not a 69 model
laven321 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2010, 09:10 PM   #7
laven321
let us know how you go
Old 06-03-2010, 01:09 PM   #8
stevefj45
Just put a rover Alloy v8 in it don't worry about big old donks
Yes they are more powerful but the weight kills the handling and the rover motor is much lighter so it still handles well
every land rover that comes with a V8 is completely alloy heads and block all of the old rovers you see on ebay for a couple of hundred dollars with the 3.5 are alloy too
I going to be putting one in a mk2 corty in the next couple of months EFI version out of a 93 Discovery
I had to replace the engine in my 4x4 and i have one sitting around looking for a rebuild i have always wanted a V8 corty so here is my chance
stevefj45 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2010, 01:29 PM   #9
stevefj45
Default (144 kg)
(144 kg)dry
Old 12-03-2010, 04:45 PM   #10
Rural 351
1000+ passes
Rural 351's Avatar
Default Nsw
Today I paid my rego and my 1972 capri V6 is now legal with its 302 cleveland C4 and 9 inch, Had it engineered by Bruce Collins in Taree the certificate cost $715, So now we know for sure that it can still be done in NSW, so if your going to do one get stuck in to it before they change any rules,
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph
https://www.facebook.com/DragRacingT...2067110055900/
http://www.cacklingpipes.com/100825_...250810_025.JPG
XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph
The faster youve gone the worse your attitude
Rural 351 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 10:23 PM   #11
Jim5_0
I keep hearing this about NSW no longer allowing V8 Capri's but the RTA's Guidlines for light vehicle modifications still contain a formula that equates to a 5300cc engine being the max into a Capri.
As these guidelines have not changed I for one don't believe that the rules have changed either yet people keep stating that a V8 Capri is now a no go in NSW without any evidence to back the statement up.
I'm still plodding along with my 5.0 and 4 speed auto conversion.
Jim5_0 is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2010, 02:39 PM   #12
Dennis8
Dennis8's Avatar
The car I'm hoping to get is a 69 model, does it matter in that year they didn't come out with a V6? Its still the same body the next couple of years?
Mine will be regoed in VIC so according to the guidelines I've looked at it looks like it will be ok. Will be a few years till I finish it though.
Thanks for all the replies.
Old 09-04-2010, 08:44 PM   #13
JG65TE
JG65TE's Avatar
Ours was approved by an engineer only 2 weeks ago in Victoria,
302 - c4 - 9 inch
JG65TE is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2010, 11:59 AM   #14
jpm600
Can i ask who the engineer was?
I'm just looking for an engineer at the moment, and it seems that 302 windsor is over the maximum engine capacity for NCOP guidelines for vehicle modifications.
jpm600 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2010, 08:14 PM   #15
V8GT
use a 289 windsor block.. makes life so much easier when it comes to engineering.
V8GT is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2010, 08:24 PM   #16
allanv6gt
Tippy-tronic Free Zone
[QUOTE=Dennis8]The car I'm hoping to get is a 69 model, does it matter in that year they didn't come out with a V6? Its still the same body the next couple of years?
QUOTE]
The 4cyl and V6 bodies are structurally different at the front end - V6 is stronger. But then, if you are going the V8 route, I expect you will be required to fit a chassis strengthening kit. (esp. if starting with 4cyl shell)
