Now Fordless
After receiving a bad comment about my engine bay from someone while at the drags I've decided to improve it a bit.
I have a few ideas and just want to see if anyone knows prices or has any advice. 1st up the coolant reservoir. I know there are polished metal ones but they're expensive. Or is there a cheap alternative? Anyone had any success painting it? 2nd the intake pipe. Ive seen a few people with a polished pipe in place of the plastic. Is there a ready made one of these to buy? 3rd. Polishing the intake manifold. Prices of doing this? Places in Perth? 4th Some after market rocker covers. Wouldnt mind some Ford Racing ones. Will need to see who distributes them in WA. Thanks for any comments/help. |
Cat be Still !!!
I have been told the genuine coolant tanks are reasonably priced.
Get a polished ally intake pipe from BPT. Other than that just a good clean, I use Armorall wash & wax in my engine bay and them chamois dry as much as you can. |
Resident AFF detailer
Was the comment because it was dirty? Or because it just looked stock??
Just buy some cheapo Export degreaser (usually get them for 95c on special at Supercheap) and give the bay a good spray, then rinse it out!
#4 | |||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
I have sprayed some paint around the bay. Just used Hi temp brake paint (left over from doing the brakes) on the heat shiled and some plastic on the fuse box. I have also seen guys on the forum paint the coolant res as well (left a pep hole to see fluid level). These are very cheap and esay to do. whats your budget? ![]() UK
#5 | |||
Now Fordless
Dont have a set budget but I dont want to spend a fortune if you know what i mean.
The comment wasnt because of the cleanliness as it wasn't dirty but just said it looked ugly. I sort of agreed with him. Quote:
Depending on what your mate drives could also reflect on his opinion.
Really depends on what you are after, a good cruiser that you are happy with a relatively stock engine bay or to go the way of upgrading with bling, that once you actually start, believe me, the bug starts and it can end up costing an arm and a leg. Good luck though, BPT are the way to go as CRAIGAU320 has recommended. That's my 2c worth |
#7 | |||
Former BTIKD
![]() Join Date: Mar 2005
#8 | |||
Now Fordless
The 5.0s arent a very attractive engine though. The main problem being the manifold with a side mount throttle body. You dont get that symmetrical look like the Commodores. |
OWN THE ROAD
TS50 T3 BUILD NO. 97 -- BLUEPRINT, AUTO, BREMBO BRAKES, PREMIUM SOUND EFII XR8 -- LEMANS RED, 5SP MANUAL, RDA BRAKE BRAKE ROTORS WITH BREMBO PADS, PREMIUM SOUND, CUSTOM LEATHER INTERIOR SHOPPING TROLLEY - FG MKII G6E WORK HORSE - P250 |
#10 | |||
Sales Representative
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
#11 | |||
Now Fordless
#12 | ||
Very nice bay Catxr8, looks very nice. I painted my coolant tank about 2 years ago(leaving the peep hole), the paint hasn't come off..cheap easy and effective..as can been seen from Catxr8's pic.
Red bull gives you wings? ![]() |
formerly "3x-puursui7"
The MSD coil packs make it look a bit tougher whilst giving a better spark, the metal intake pipe is a good cheap one and really easy, colour coding the intake pipe connectors with spark plug leads and maybe some other stuff will also tidy it up.
I got these rocker covers from the states absolutely love them but had to modify the accelerator cable bracket, and im yet to install the r/h one as the filler neck needs slight modifying but thats out of my skill range! the last photo is how it was when i brought it, im still undecided on the cover going back on as it hides a few of my goodies which is good and bad. ![]() ![]() ![]() and yes that manifold is rather ugly, the plan is to get it painted wrinkle black like the rocker covers and try polish the row of ribs across the top then i think it wouldn't stick out like dogs balls!
all hail the mighty V8's ![]() http://www.aufalcon.com.au/3x-puursui7 |
#14 | ||
Boost is here!!
Plenty of choice with rocker covers.
To get the Explorer polished your looking at around $200. Take it off and go see Matt @ Refleks Metal Polishing in Malaga. He can also polish your T/B and MAF housing aswell. And any other little bits you think of, like thermostat housing etc. You could pay a fortune for an ally intake pipe from BPT or you could just spend $40 on a 3" 60degree stainless mandrel bend, cut it to size, drill a hole for IAT sensor and get a rubber grommet to suit. Then 2 x 3"-3" silicone joiners and 2 extra hose clamps and thats it. Send that to the polishers aswell before it goes back on. As you said, a nice PWR header tank is a good idea. Or could just paint your original one in your preferred colour. Also, if you have your engine cover on all the time, could look into painting that up abit. Other than that mate, its just a matter of keeping all the black plastic/rubber parts shiney and everything else clean. This isnt the best pic i have of it, but only one on photobucket. Mates engine bay in his AUII 220. He had it looking abit better than that too, by polishing the MAF housing, changing those silicone joiners to black and getting a new header tank. ![]()
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
#15 | ||
Now Fordless
Yeah the issue I got with BPT pipe as well is its made up of a number of pieces so there is ugly welds all up it. Would rather a one piece pipe like the one above.
Im thinking of colour coding the engine cover but dont know where to get some Narooma paint from. With the rocker covers is there anywhere I can just go in and buy them instead of dealing with the US or over east? |
#16 | ||
Boost is here!!
Narooma paint could be bought from any auto paint store, like Protec etc. Have a look in the latest PSC, or may have been the one before, it had a thing about some company putting whatever paint you want (genuine Ford colours etc) into a pressure pack. Dunno what the finish would be like, but if ya knew what u were doing it couldnt be too bad.
Yeah u can get rocker covers from Perth, but you'll pay top dollar for them. Search for the ones you want, then give places like A1HiPerformance or CMP a call.
