Old 19-11-2009, 07:46 PM   #1
toyotaxr8
toyotaxr8's Avatar
Default How to workout top speed
I am wondering how you work out top speed that a car can theoretical get up to not including factors like wind, drivetrain losses and stuff like that. My combo is going to spin to 9000rpm through an AOD with a final gear ratio of 0.67:1 then to 3.9:1 diff gears and out to the 26x11x15 inch tyres any help would be greatly appreciated.
MR INCH
toyotaxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2009, 07:59 PM   #2
4VCLEVO
XA GT
4VCLEVO's Avatar
This site will tell you but you will need to know the convensional tyre size, ie: 265/60 15.
http://www.boosttown.com/gearbox_dif...calculator.php
XA GT, 6.848sec 1/8 mile @ 101.68mph
4VCLEVO is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2009, 08:03 PM   #3
Falc'man
You dig, we stick!
Falc'man's Avatar
Jack it up and rev it's bits off in top gear.
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2009, 08:08 PM   #4
4VCLEVO
XA GT
4VCLEVO's Avatar
Just had memories flood back of Ferris Bueller's Day Off.
Old 19-11-2009, 08:12 PM   #5
Deech
Making smalltorque
9000 input shaft RPM
/0.67 = 13432.85 RPM output shaft
/3.9 = 3444.32 RPM at the ring gear/halfshafts
Assuming your tyre dimensions are 260mm/11%/15" (260/11/15), diameter = 43.82cm
=1.38m circumference = 4741.60 m/min.
4.74k/min
=284.49 km/h.
Originally Posted by sourbastard
E Series Owner Syndrome
When your engine bay catches alight, you try and convince the police that it came that way from the factory. They believe you and leave.
Deech is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2009, 08:12 PM   #6
toyotaxr8
toyotaxr8's Avatar
thanks for that, 428.93km/h top speed in perfect conditions
MR INCH
Old 19-11-2009, 08:22 PM   #7
Deech
Making smalltorque
If your engine does 13536.16 RPM?
Old 19-11-2009, 08:37 PM   #8
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
4.74k/min
=284.49 km/h.
Deech, the size is the imperial measurement. ie the tyre is 26" tall = the diameter is 26" which is 660mm tall.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2009, 08:38 PM   #9
Deech
Making smalltorque
Ahhh. I stand corrected. Yep, 428.5 km/h.
Assuming I learn to read dimensions properly diameter = 0.66m. pi*diameter =2.073 m circumference
=7141.62 m/min.
7.14 k/min
=428.498 km/h.
Old 19-11-2009, 08:54 PM   #10
Deech
Making smalltorque
Thanks Phillyc.
OP, sorry about the initial misinformation.
Old 19-11-2009, 09:19 PM   #11
xbgs351
All you need now is a 428.5 km/h tail wind and you will be set!
xbgs351 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2009, 09:26 PM   #12
yetchh
go bro
yetchh's Avatar
this is a pretty good program and its free
http://locost7.info/gearcalc.phphttp...o/gearcalc.php
gives speeds in each gear, rev drops, speeds at max power and max revs etc
1976 351 xc fairmont wagon.
1974 original XB Landau.
1963 MK3 Zephyr
1977 RX4/929 coupe in epoxy finally
1976 121 Cosmo 2l turbo
yetchh is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2009, 09:54 PM   #13
4VCLEVO
XA GT
4VCLEVO's Avatar
The link doesn't seem to work.
Old 20-11-2009, 03:31 PM   #14
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
http://www.locost7.info/gearcalc.php
Old 22-11-2009, 08:37 PM   #15
yetchh
go bro
yetchh's Avatar
sorry i doubled up by mistake... outback_ute's got it right
1963 MK3 Zephyr
Old 22-11-2009, 10:00 PM   #16
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Yeah and by those figures my stock as a rock auto AU six cyl has a top speed of a bit over 300!
YEAH RIGHT
Old 23-11-2009, 12:23 AM   #17
SLO AU XR8
YEAH RIGHT
the theoretical top speed mey be that high, but power + drag mean limited speed figures
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2009, 01:25 AM   #18
imugli
His daily is the McLaren MP4-23
imugli is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2009, 06:46 PM   #19
toyotaxr8
toyotaxr8's Avatar
that would be tail shaft rpm, so it is not that much.
13536.16x0.67(overdrive ratio)= 9069.2272
MR INCH
