Old 07-11-2009, 08:21 PM   #1
shayne_xr6t
Default Help just installed asl rgb converter picture is rolling
Just installed the ASL rgb converter kit, using an Alpine dve-5207 stand alone dvd player sound works great but picture is rolling fast with no colour, have i connected it wrong? would the converter be faulty?
shayne_xr6t is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2009, 08:37 PM   #2
gravelrash
switch it to NTSC instead of PAL. what i did is disconnect it from the car, run a longer RCA cable to a portable tv. plug it in. go to settings, change it from PAL to NTSC. then disconnect it and plug it back into your car.
gravelrash is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2009, 09:38 PM   #3
shayne_xr6t
i just tryed that and no picture at all no signal, is that what an pal signal looks like trying to go through an ntsc screen, rolling and jumping around? or is there no picture at all?
maybe because the tv is pal and the dvd player is actually playing ntsc?
i dont know ay but its getting annoying
Old 07-11-2009, 11:06 PM   #4
gravelrash
correct. a PAL signal continually scrolls on a NTSC screen. change the tv setting to NTSC and see what happens.
Old 08-11-2009, 12:15 AM   #5
shayne_xr6t
hey mate yep plugged it all back in again tryed it all apparently my dvd player automatically sets itsself to pal or ntsc plus when i had it running on the tv there was no option to change from pal to ntsc signal due to it being auto so that eliminates that possibility what else could it be ive tryed several dvd players and all have the same rolling picture no matter what setting is used
Old 08-11-2009, 02:34 PM   #6
shayne_xr6t
ok just took it to xtreme car audio they tryed a few things which didnt work either, they tryed hooking up some of their dvd players to my tft screen through the converter and still the same rolling picture, they also tryed a PAL reverse camera which worked on the tft beautifully, i tryed another dvd player of mine an alpine dva-5210 which allows you to set it to ntsc manually which it did display normally until i put a dvd into it then it went back to rolling picture, ?????
Old 09-11-2009, 08:20 AM   #7
FADI75
Sponsor
hi
sounds like you are using a PAL device, if you still having a problem please call us 0397991444
ASL
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2009, 10:38 PM   #8
shayne_xr6t
desicion made selling alpine dvd players due to incompatibility and will more than likely going for the ASL dvd player, just wanted to know? is it a good dvd player? will deffinatly work straight away with playing everyday ordinary dvds?
Old 10-11-2009, 08:13 AM   #9
FADI75
Sponsor
hi
you will be impressed with the ASL DVD, it plays all DVD's, Divex mp3 mp4 usb sd cards etc...
cheers
ASL
Old 23-11-2009, 01:20 PM   #10
shayne_xr6t
just like to thank fadi and karl for the support in solving a few problems the new asl dvd player is working well very impressed by it, i have one last question, im not getting any bass through the factory subwoofer through the dvd player like the factory headdeck does why is this?
Old 23-11-2009, 01:41 PM   #11
FADI75
Sponsor
hi
im glad we sorted your issues. And thanks for the good feedback.
the dvd player runs through AUX therfore Dvd sound will not go through the woofer, it is normal.
cheers
fadi75
Old 26-11-2009, 11:37 PM   #12
shayne_xr6t
why is the sound quality low when playing cds or sd card music or dvds? have i got the 2 sound rca plugs plugged into the wrong rca inputs on the dvd player? noticed that there is more than one of the red and yellow rca inputs on the dvd player, the sound quality is a little distorted compared to the separate boosted ipod aux kit which is crystal clear sound
