Old 31-10-2009, 08:27 AM   #1
nuckenfutsmk1
Default 2LTR TORQUE SETTINGS PLEASE SAT 31 OCT 8.23am
Really need the torque setting for a 2LTR fly wheel to crank
pressure plate to flywheel
I have searched the net and found nothing
So if someone can pull out the Gregorys manual and help us out the would sweet as : : : :togo: : :
nuckenfutsmk1 is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2009, 09:17 AM   #2
tufLTD
tufLTD
tufLTD's Avatar
Are you using standard bolts?
If so, flywheel bolt torque is 75 ft/lbs, pressure plate bolts 15 - 20 ft/lbs.
I always use something like Loctite 242 medium strength on flywheel bolts.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2009, 01:21 PM   #3
nuckenfutsmk1
Cheers big help if I cant find that book i may need a few more later on
Old 04-11-2009, 07:29 PM   #4
nuckenfutsmk1
Any one got the the head torque settings
Old 05-11-2009, 03:59 PM   #5
Billit1000
Billit1000's Avatar
75 ft\lbs is what i've always done them too. Your gasket set should tell you the tension, but usually its a broad spread.
When the flag drops...
The bullsh!t stops...
Billit1000 is offline   Reply With Quote Multi-Quote with this Post
