Old 26-10-2009, 01:13 AM   #1
Ibrox90
Ibrox90's Avatar
Default Acelleration
I found this in my random internet ponderings:
"A lesson in acceleration but first some useful information:
One Top Fuel Dragster 500 cubic inch Hemi engine makes
more horsepower than the first 4 rows at the Daytona 500.
Under full throttle, a Top Fuel Dragster engine consumes
1.5 gallons of nitro methane per second; a fully loaded
747 consumes jet fuel at the same rate with 25% less energy
being produced.
A stock Dodge 426 Hemi V8 engine cannot produce enough
power to drive the dragster’s supercharger.
With 3000 CFM of air being rammed in by the supercharger
on overdrive, the fuel mixture is compressed into a near-solid
form before ignition. Cylinders run on the verge of hydraulic
lock at full throttle.
At the stoichiometric 1.7:1 air/fuel mixture for nitro methane
the flame front temperature measures 7050 degrees F.
Nitro methane burns yellow. The spectacular white flame
seen above the stacks at night is raw burning hydrogen,
dissociated from atmospheric water vapor by the searing
exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This
is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass.
After half way, the engine is dieseling from compression
plus the glow of exhaust valves at 1400 degrees F. The
engine can only be shut down after cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro
builds up in the affected cylinder and then explodes with
sufficient force to blow cylinder heads off the block in
pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must
accelerate at an average of over 4G’s. In order to reach
200 mph well before half-track, the launch acceleration
approaches 8G’s.
Dragsters reach over 300 mph before you have completed
reading this sentence.
Top Fuel engines turn approximately 540 revolutions from
light to light.
Including the burnout the engine must only survive 900
revolutions under load.
The red line is actually quite high at 9500 rpm.
The Bottom Line; Assuming all the equipment is paid off,
the crew worked for free, and for once NOTHING BLOWS UP,
each run costs an estimated $1,000.00 per second. The current
Top Fuel dragster elapsed time record is 4.441 seconds for the
quarter mile. The top speed record is 333.00 mph as measured
over the last 66’ of the run.
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter twin-turbo
Corvette Z06. More than a mile up the road, a Top Fuel
dragster is staged and ready to launch down a measured
quarter-mile as you pass. You have the advantage of a flying
start. You run the Vette up through the gears and blast across
the starting line and past the dragster at an honest 200 mph.
The “tree” goes green for both of you at that moment. The
dragster launches and starts after you. You keep your foot
down, but you hear a brutal whine that sears your eardrums,
and within three seconds, the dragster catches you and
beats you to the finish line, a quarter-mile from where you
just passed him. From a standing start, the dragster spotted
you 200 mph and not only caught you but nearly blasted
you off the road when he passed you within a mere 1320 feet.
That, my friends, is acceleration!!
via Bandit,
kf6hqc
HIS
THUNDER
2004 BA XR8
Blueprint
Mods:
Quad Exhaust, Hi-Flow Air filter, BFtiming chain tensioners, Billet Oil pump gears
stage 2 shift kit, riding on G6ET 18's
HERS
FLASH
BA MKII XR6 Turbo
Phantom Purple
Typhoon front end
Parking your ford after a long day of being Awesome
http://www.facebook.com/pages/Parkin...37774932974038
Ibrox90 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 01:25 AM   #2
greenfoam
And then you pull the engine down and rebuild it because everything is stuffed . They make great power for what they are but the 747 needs to do more than 20 meters down the runway before it falls apart
greenfoam is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 01:36 AM   #3
tufLTD
tufLTD
tufLTD's Avatar
The statistics for these monsters is absolutely amazing. As Jim Read said, "These things can rotate the earth".
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 08:44 AM   #4
ltd
Force Fed Fords
ltd's Avatar
He he he
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 11:09 AM   #5
kircher
kircher's Avatar
These things are amazing. The sound is even more brutal than the acceleration. If you haven't seen them I recommend you do, and don't use hearing protection for at least one pass.
That's a cheap shot at 747s though, They've been an amazing plane over their long career. Several times they have quickly and safely taken me right across the Pacific.
kircher is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 11:13 AM   #6
FreddyDUZ747
FreddyDUZ747's Avatar
Walking under the tunnel back in the days of top fuellers(AIR)was a great noise to hear,went straight through ya.
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 12:00 PM   #7
Paddyboy
Paddyboy's Avatar
thats bloody amazing!!
I love the corvette bit of info, can you imagine been in that corvette! 200mph is insanely fast, but for a dragster to launch from nothing as you pass and catch up in 4 seconds is mind boggling! The drivers of these cars must have balls!
“She said, 'I'm your biggest fan,' and I said, 'Who are you?' She said, 'Paris Hilton.'”
Ricky Gervais
Paddyboy is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 12:19 PM   #8
Ibrox90
Ibrox90's Avatar
I reckon the need a certain amount of testicular fortitude. But i think really there just hanging on.
Years ago when i was around 5-7 mum bought me a VHS tape called "And they walked away" it was just filled with american topfuels crashing and flipping.
HIS
THUNDER
2004 BA XR8
Blueprint
Mods:
HERS
FLASH
BA MKII XR6 Turbo
Phantom Purple
Typhoon front end
Old 26-10-2009, 04:58 PM   #9
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
6.3@220+mph on a top fuel bike, now that takes balls!
BENT_8 is online now   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 05:08 PM   #10
Nikked
Oo\===/oO
Nikked's Avatar
Top Fuel dragsters also out accelerate the Apollo rockets don't they?
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 09:33 PM   #11
Iggypoppin'
Chasing a FORD project!
Iggypoppin''s Avatar
Top fuel dragsters are currently the fastest accelerating device built by man. They do out-accelerate rockets, imagine a rocket launching 400m in. 5 seconds, they take longer than that for sure.
Originally Posted by HSE2
Today we might get beaten at some of our own game. Tomorrow we reinvent it.
Game. Reinvented.
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon.
Iggypoppin' is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 09:48 PM   #12
DJM83
Barra Turbo > V8
DJM83's Avatar
Thats insane
-2011 XR6 Turbo Ute - Lux Pack - M6
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 09:55 PM   #13
SSD-85
Correct. But those rockets also produce faaaar more thrust. Plus Top fuellers dont have to try and escape the earths' gravity. The trick is traction, driving rubber to the ground has much better propulsion characteristics than trying to force burning gases through thin air.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 09:56 PM   #14
FreddyDUZ747
http://www.youtube.com/watch?v=2tg6R...eature=related
Side by side mid 4s,one of my favourite 1/4 mile videos.Only goes for a minute max.
http://www.youtube.com/watch?v=rHAZM...eature=related
And heres a little thrust.17 seconds.
Old 26-10-2009, 10:06 PM   #15
Falcman0o7
Falcman0o7's Avatar
thanks mate. a good read indeed. unreal!!!
Falcman0o7 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 10:16 PM   #16
XR Martin
XR Martin's Avatar
Yeah but a top fuel engine wouldnt even be able to power the Saturn Vs fuel pumps. (55000hp)
2004 BA wagon RTV project.
Old 27-10-2009, 09:56 AM   #17
ltd
Force Fed Fords
ltd's Avatar
What is with this "mine is bigger than yours" complex?
I get to play with 240,000hp and I think it's a bit sluggish.
What about that dude in the 60's on the rocket sled, didn't he accelerate at something like 10G's, all the way up to over 1000 mph only to meet deceleration of over 45G's; where his retinas detached etc?
Powered by GE
Old 27-10-2009, 10:19 AM   #18
flappist
Not even remotely close......
Old 27-10-2009, 12:58 PM   #19
PALE ALE
In a fuel car, you actually want a slight amount of wheel spin to accelerate the car. It needs to "get up on the tyre" (stand up on the tyre, you will see the tyre grow tall). Tuners are looking at the data, and want x amount of wheel speed, at a certain point in the run." its all in the clutch"
A fuel car, has a centrifical clutch (Yamaha pee wee 50) a 3.20:1 diff ratio, and 1:1 direct drive(no gear box). Basically its like taking off in your car in 4/5 gear, and riding/slipping the clutch to get going
Maybe I should start a thread in "Project Cars" on a fuel car. I am part of a fledgeling Fuel Car team here in Adelaide (Scott Ferguson/Gary Evans) But I dont want to go "Blowing our horns" about it, because it may never happen. It has taken an obscene amount of money, blood, sweat and tears to get where we are, and we still have a long way to go yet, and at times things get frustrating and overwhelming and I think we are kidding ourselves, but we havent given up yet.
But just for interests sake, I could take some pictures of the car and various parts and explain how certain things work, some of it is truely mind blowing stuff, and makes any other motorsport look meek
PALE ALE is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 01:25 PM   #20
Fev
Fev's Avatar
That would be really cool Pale ale! Would be good to see the details and inner workings
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 02:38 PM   #21
1LOUDXFUTE
1LOUDXFUTE's Avatar
yes please! :
My BA XT Build Thread
1LOUDXFUTE is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 03:35 PM   #22
Neeek
65 Galaxie Hardtop
Neeek's Avatar
Hell yes!
Red on red 65 Galaxie 390FE C6 9"
Neeek is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 04:32 PM   #23
Piotr
Non-Regular Member
approaches 8G’s.
300mph in 4.5second is an average of ~3g not 4g
2005 Renault Sport Megane 225
Old 27-10-2009, 05:42 PM   #24
sly_ba
I really do admire the engineering that goes into these cars, however, it makes my mind boggle when I think about all the money and man hours spent on the cars and engines all for the sake of one 4-5 second pass...... Don't get me wrong, I'm a motor sport nut, it just seems like the enjoyment is so short lived for such a massive outlay. Even if it doesn't go bang making a pass (which they do about half the time) they still need to be rebuilt anyway......
sly_ba is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 10:53 PM   #25
chrisfpv
Browsing here and there..
chrisfpv's Avatar
Great read, thanks.
chrisfpv is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2009, 12:23 PM   #26
KPOJ
Awesome read, thanks.
KPOJ is offline   Reply With Quote Multi-Quote with this Post
