Old 09-10-2009, 03:35 AM   #1
Gaz
Got Ghia?
Gaz's Avatar
Default Hydrogen xr6t motor
Saw this at a conference in Melb this week, being done by one of the uni's.
Wouldn't tell me any specifics about consumption or boost figures other than they are at comparable power levels.
Thought it just might be of interest to some people here so throwing photos up. It's essentially stock with new pistons to run ~12.5:1 compression.
Also there was something they are about to start some work on. It will be using standard petrol injection, however it will be hydrogen ignition. Petrol is injected as usual, however a small amount of hydrogen is injected into the spark plug cap (shown in photo) and then ignited, which in turn ignites the petrol. They weren't overly forthcoming with large chunks of information on their expectations but sounds interesting.
I asked them if they had tested the limits but alas no the softies aren't interested in pushing limits at this stage. :
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 08:36 AM   #2
JPFS1
JPFS1's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community.
I believe they've been working on this for a few years... Monash iirc??
JPFS1 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 08:56 AM   #3
ltd
Force Fed Fords
ltd's Avatar
Good to see that an Aussie motor is being the guinea pig. If they are getting the gains that they have stated getting, surely this will attract a much wider audience in the international motoring community.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 09:50 AM   #4
Fairlane
V8 Powaah
Fairlane's Avatar
Gotta love Australia, only in Oz could Uni researchers working on a Hydrogen motor drink Beer in the lab.
Looks very interesting though, first ive heard about it.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 10:34 AM   #5
Paxton
Cobblers!
Paxton's Avatar
Yep. Monash.
With the I6's stay of execution, you could almost say that it is future proof.
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 10:53 AM   #6
mikestp
EF Ghia
mikestp's Avatar
Hopefully this helps set a hydrogen powered future, rather than an electric future
mikestp is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 05:16 PM   #7
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Then end up in an even worse "global warming" situation then we are facing now? Water vapor holds in much more heat than CO2.
Disclaimer:
I don't support global warming.
Old 09-10-2009, 08:51 PM   #8
tezxr8man
didnt ford donate a few motors to monash a couple of years ago for these types of experiments?
Its good to see people trying something other than electric, all the crap that goes into makin it and the batteries probably make as much enviro dramas anyway
Someone mite know more than i do about this but aren't ford in the states running hydrogen v10's in the f-trucks in some of the airport buses over there too?
tezxr8man is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 09:13 PM   #9
S3SR
S3SR's Avatar
ford made their superchief run on 3 different fuels, diesel, biodiesel and hydrogen iirc
V10 goodness and save the planet
i should have finished engineering at uni, we made our own FSAE car and thought that was exciting.
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 09:27 PM   #10
SSD-85
Disclaimer:
Water vapour is also an elevated temperature substance of, you guessed it, water. Once it condenses due to exposure of cooler conditions it turns back into water.
I wonder what clouds are made of...? :
CO2 on the other hand, stays in its current form unless extreme temperatures are applied. It also takes a rather long time for CO2 to dissolve in the oceans and eventually take part in the formation of limestone.
Yes true it is a greenhouse gas, but it is also MUCH easier for the atmosphere to break down back into water.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 09:30 PM   #11
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
Disclaimer:
You've rather neatly forgotten that combusting petrol creates water vapour too... Loads of it.
For every 2 Petrol (C8H18) molecules you add 25 Oxygen (O2) & the result is you get 16 Carbon Dioxide (C02) & 18 Water (H2O) & 10.86MJ of energy.
Hydrogen will most likely be made the way it usually is now. Electrolysis. 2 water (H20) molecules are broken down into 2 Hydrogen (H2) & 1 Oxygen (O2). When Hydrogen is burned it then becomes H20. Back to where it started.
Yes energy is required to make it, to store it and transport. But petrol is not much different, but instead of making it, we drill for it.
Hydrogen is already one of the most common industrial gases anyway.
So, you perhaps should be more worried about water vapour from petrol. Besides it condenses in the end anyway. But yes, that newly formed water will have the ability to store heat.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 09:31 PM   #12
madmelon
Wow look at those lambda numbers.... nothing below 1! Lambda 3.5 is 52:1 equivalent to 52:1 AFR on petrol!
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2009, 09:35 PM   #13
phillyc
phillyc's Avatar
Well. What a great piece of engineering by the Monash boys and a terrific motor to base it off! Go the mighty injected hydrogen turbocharged Falcon 4 litre in line six!
Retrotech thread
Old 09-10-2009, 09:41 PM   #14
madmelon
...and now look at that torque value at peak efficiency. 125Nm at the flywheel is pretty abysmal for a turbo 4L- even the older 4L engines are over 250Nm at idle with WOT.
Old 09-10-2009, 09:44 PM   #15
madmelon
Actually, the overwhelming majority of current hydrogen production is by catalytically removing it from hydrocarbons...
The remaining carbon is either captured (if in CO2 form, which it may well be) or burried (solid form)
Old 09-10-2009, 09:47 PM   #16
SSD-85
Correct
Old 09-10-2009, 09:58 PM   #17
phillyc
phillyc's Avatar
I stand corrected.
I knew they were looking at using fuel cells to rip hydrogen from hydrocarbons to generate electricity, didn't know that was being industry wide for hydrogen production.
Retrotech thread
Old 09-10-2009, 11:54 PM   #18
Bossxr8
Peter Car
Bossxr8's Avatar
I think its a 3 way tie up between Ford, Monash and the Vic government. Ford provided engines and some funding.
Old 10-10-2009, 09:32 AM   #19
Franco Cozzo
Thailand Specials
Haha well looks like I got shut down, I'm basing my knowledge on year 11 environmental science (which we all dropped). Though, I heard an interesting fact while we're on global warming, humans contribute a huge 3% to all greenhouse gasses, volcanoes and fires do much more than what we can. How true that is, I don't know but its worth bringing up.
Old 10-10-2009, 10:49 AM   #20
MRFGXR6
MRFGXR6's Avatar
Default Hydrogen way of the future?
Count me in on one if it ever reaches the consumer market. Will be much better than the petrol based I6 and the oil companies can then jam their ever escalating fuel prices where the son doesn’t shine. This is the way the Aus government should be going as well, not just with the electric based slot cars. If I could get my hands on Fords US based Hydrogen powered supercharged V10 and slot it in the FG I would be a very happy man indeed. Kill two birds with one stone, plenty of power and please the do-gooders of today’s society.
Well only time will tell.
6/6/16 build 2017 plate Race red mustang gt with white solid stripes, tint, x-force exhaust, rear spoiler, 35mm lowered Votgland springs
MRFGXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 09:00 PM   #21
Danman
Default Hyrogen here now in Kits form USA $100
Check the site. www.hydrogenboostnow.com making them ready to go.
Love to know if anyone has fitted one on a Territory. I'm not game to be the first, but it all seems to be the way of the future.
Danman is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 09:27 PM   #22
Iggypoppin'
Chasing a FORD project!
Iggypoppin''s Avatar
I know nothing about hydrogen fuel at all so I'm going to ask the ignorant questions: does hydrogen burn in the combustion chamber the same as fuel/air vapor? As in, is it squirted in via an injector, then ignited, or...? Like I said I'm confused and ignorant. Does the energy produced from hydrogen burning equal that of petrol if you burned the same quantity of each fuel? This thread has definetly got me curious.
Originally Posted by HSE2
Today we might get beaten at some of our own game. Tomorrow we reinvent it.
Game. Reinvented.
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon.
Iggypoppin' is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 10:05 PM   #23
SSD-85
From what I have read, yes hydrogen will theorectically burn in a combustion chamber. The problem is delivery. Also as far as im aware, Hydrogen produces less energy than petrol of equivalent mass.
EDIT: But in saying that, H1 burns more efficiently. Since next to no by-products are produced, unlike petrol which creates all sorts of by-products. Thus more went into the energy than into the "leftovers".
Old 26-10-2009, 10:10 PM   #24
GTP 290
GTP 290's Avatar
This will never reach the public consumer market. Oil companies make to much money to allow something like this to slip through and cut them off. There have been so many people in the past that have succsesfully designed and built hydrogen powered cars where all you have to fill your tank with is water. Then miraculously they either dissapear, die or in the case of Stan meyer (google him), gets assasinated.
I'm no conspiracy theorist but it seems as though the knowledge and ability has been around for many many years yet no one has ever brought out a car that can be run purely on water.
GTP 290 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 10:13 PM   #25
Iggypoppin'
public revolt against petrol companies sometimes seems a good idea at times......sigh.
Game. Reinvented.
Old 26-10-2009, 10:15 PM   #26
SSD-85
What a day that would be. We can still have the lovely rumbling of burning gases and all we produce is water vapour and nitrous oxide...
Ill hand in my license the day im forced to drive an electric car. :togo:
Old 26-10-2009, 10:22 PM   #27
Iggypoppin'
it'll be a loooong time before that, but i'd be topping myself if it did come to that.
does anyone agree with this theory?
oil companies are investing heavily in alternative fuels, while "silencing" any private sector that comes up with the technology first, so that when the time comes to begin the phase out of oil(exponential # of years, as we don't know how long the oil will really last) they can immedietly prop themselves up on an alternative fuel and thus not "go under"?
Game. Reinvented.
Old 26-10-2009, 10:38 PM   #28
Spanrz
Hmmmmmmm!!
Isn't Hydrogen a slower burning substance than petrol?
http://www.youtube.com/watch?v=PVv0NVLFPig
Still beg to differ? Potential is there.
Spanrz is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 11:17 PM   #29
SSD-85
Yes I do. Im well aware of electric potential. Power is not the reason for my comment. I enjoy the noises of big, lumpy, inefficient internal combustion engines. Silly as that seems...
Old 27-10-2009, 12:38 AM   #30
MGR
MGR's Avatar
Nobody has ever successfully designed and built hydrogen powered cars where all you have to fill your tank with is water.
Stan Meyer was a convicted fraudster.
Nobody has ever brought out a car that can be run purely on water - because it is impossible.
Google "First law of thermodynamics"
MGR is offline   Reply With Quote Multi-Quote with this Post
