![]() Join Date: Nov 2007
Gday all.
Looking for traction as my single legger 3.23 fairmont diff is woefull! Obviously LSD is the best for drivability- as my car is my daily driver, but a little too $$$$$. I can get a Mini spool and 3.7's fitted for around $700.00 (mates rates). What are peoples thought on this? Am i better to outlay the extra coin and get a complete LSD centre and buy 3.7 gears, or go the gears and spool? Also will a LSD centre out of an EF/EL fit a solid axle AU diff?
RIP...
LSD is the only option for road use.
Aside from being illegal, a locker is pretty difficult to drive on wet roads, dangerous in the wrong hands. In the dry they are very hard on axles, tyres, suspension parts, etc. A good LSD has all the advantages of a locker, without the disadvantages.
. Oval Everywhere... |
Any idea on the centre, are they interchangable with EF/EL?
RIP...
Yes they are interchangable.
excelent thanks mate
spool=equal drive,consistancy,less wear and less maintanence.
ive had a few lsds(new)and the only thing that turns me off is the clutch wear and inconsistant drive.a spool can be a pain,but with good tread on tyres theres minimal skip or noise.if you let you tyres run low thats when they tend to screech a bit.if you get a locker your driving style only has to change a fraction.take that corner,roundabout a little slower,u turn a lttle wider or faster(in dry).a spool should not be confused with the harshness off a welded diff especially in a modern car. |
Spools cause more maintenance when you twist and snap axles, for consistency and legality, a Mechanical locker like the 4wd System's Lokka would be best IMHO
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
#8 | |||
Just slidin'
Its not s Detroit Locker, its a 4wd systems LOKKA, the brand is LOKKA. They are open unless accelerating or decelerating, so dont chew tyres like a locker, or welded diff, plus they are legal.
MD Mondeo - For the family
Stroking it...
+1 for a LOKKA, if they are sprung (i think is the term?) correctly they are great, would happily put one in my AU
Had: 347ci AU Then: ![]() Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
#11 | |||
#12 | ||
Just slidin'
Yeah, go the spool, get booked for it, crash and then when insurance wont cover you, come here and complain.
#13 | |||
RIP...
The end result is the same thing.
#14 | |||
RIP...
#15 | ||
Just slidin'
U - turn wider and faster, awesome. I might get me a spool, lol.
#16 | |||
RIP...
#17 | ||
A 4WD system Lokka, fit's inside you Std Open carrier and replaces the spider and side gears and is less expensive than a Detroit locker
A Detroit> Is a complete carrier/Locker in one and is basically bullet proof but they are not cheep around $1000 for the carrier/locker assembly, I have one in my Hilux and they are grate! IMO a Detroit or Lokka Style diff on a street driven car is overkill, Go a conventional LSD or one better would be a Detroit Tru Trac LSD, it's a gear driven LSD and will never wear out like a clutch LSD will. If Cash is tight i would get a 4WD systems unit over a spool! Spools can be dangerous especially on wet greasy roads.
FPV GS ute 5.0 S/C Twin 3-inch, pacemaker headers |
#18 | |||
Once PHASED.
2006 BF XR8 Bionic. |
#19 | ||
LSDs are probably the best to drive with but the standard ones require high maintenance when giving them a hard time and tend to single spin. You can get them shimmed or tightened which helps alot IMO and you wont have to worry about spinning one wheel for a while. I have a Kaaz 2 Way LSD which is pretty expensive but definetly worth the money as I have never driven a car which drives so smoothly and has so much grip to offer.
The reason i went the Kaaz is because i used to own a 4wd systems lokka. The lokka behind my car was terrible. I have heard good comments about them behind an auto but behind my manual it was the worst driving experience ever. Every time i took a corner there would be big vibrations going through the driveline with loud clunkings coming from the diff. Sometimes through small turns the diff would make a huge BANG, i had someone in the backseat when it happened and lets just say he was a bit nervous after he experienced that. I went through 2 gearboxes and had 3 experts drive the car (a diff specialist, a mechanic and a representive from BTR) all pointed there finger at the diff. I would never buy one again and will never recommend one based on my experience. IMHO and from my experience i would save the coin and get a second hand LSD centre, get a diff specialist to tighten it and you wont have to worry about it letting go for a while.
Current: Built R32 GTR 520Hp ATW AU3 Fairmont I6 Whiteline swaybars, FPV Typhoon Rims, Superlows, Custom Intake Piping, Modified BA XR8 Airbox, Big Stereo Past: 2001 AU2 XR8 220 Manual 1/4 Mile: 13.8 @ 100MPH (161km/h) Ford Falcon AU2 V8 Auto 1/4 Mile: 13.0 @ 107MPH (172km/h) |
#20 | ||
i think we should leave all the answers to the keyboard warriors(sox,monty),even though both have probably never experienced anything to do with lokkas.this is a forum for opinions and such yeah albiet deemed wrong by some?the thread was lsd vs spool not try pay someone out who is speaking from FIRST hand experience about the thread lsd vs lokka.these guys should be given the same warnings as the people who chat in sales yard,no talking off topic(drastically)as how is this helping the guy with his question.i get off on helping someone not putting them down.truth hurts?
#21 | ||
Just slidin'
Sox - 57 The Monty - 54 Gillmore - 0 I think that speaks for itself.
#22 | ||
thats purely a toss factor mate.doesnt help yous in real life does it or make you understand cars more?my rep power exists only on the strip where it counts boy.bias?
#23 | |||
RIP...
He clearly stated it's a daily driver, and then went on to ask what is a better choice for his car. We gave him our opinion based on that. You clearly gave him your opinion based on what you have in your 'strip' mind. If you do all your talking on the strip, that's fine, but what works best on the strip (and for you), does not work best on the road and for others. Locked diffs are illegal on the road for a pretty decent reason IMO. The road and race track are very different places. Stop being a tool, and post something to actually defend your reasoning, rather than the virile which you posted above.
#24 | |||
Clevo Mafia Inc.
![]() Join Date: Dec 2004
The on topic posted by yourself is actually advocating an inexperienced person modifying their car in a manner not only dangerous but against the law. You then flame these blokes for doing what is essentially right calling them keyboard warriors, i think we know who is whom in this discussion. As for the question in hand, i would go the LSD unless the budget will stretch to an Detroit locker, True Trac, or the aforementioned 4WD Systems - LOKKA. Last edited by Falcon Coupe; 22-05-2009 at 07:06 PM. |
#25 | ||||
This is not the words of someone with experience, I have had cars with spools and cars with welded diffs, the only difference being cost (if you know how to weld). But I do agree with you, lsd's can be inconsistent and unpredictable, but cars with spooled/welded diffs aren't a joy when trying to park to attempting a 3 point turn. Out of the options, if lack of traction isn't a big issue I'd stick with a single spiner and decent tyres of course, otherwise for street use lsd's and don't drive like a tool, non street driven car, spooled only because my welder was stolen a year ago ![]() |
#26 | |||
#27 | ||
A spool in a daily street driven vehicle is just plain stupid. Its asking for trouble in every aspect.
335 S/C GT: The new KING of Australian made performance cars.. ![]() |
#28 | ||
thats for all your point of views. It is street driven, it is raced. I will have to work out a happy medium.
#29 | |||
Clevo Mafia Inc.
#30 | ||
I have had LSD's before. I have also broken LSD's before. Will do some more research into diffrent options.cheers.
