Has anyone fitted these kits on their AU's at all. Apparently there is a different kit for 8's and 6's. I got the one for my XR8 as they unbolt from the wheel well and not the engine bay. They say to fit a washer on the lower bolt on the engine bay side but it just dosn't look right just putting a washer on one bolt, it won't let the plate sit flush with the body and will put it on a bit of an angle.
Just wanted to know if this is correct or have I done it wrong!!
We salute those brave souls that enter the DARK side |
Fixing Ford's **** ups
Sounds alright. The shims actually change the angles. The washer may just alter the angle to begin with, but when the shims are added, it'll all be correct. So, I think you're just stressing a little unnecessarily
Checked with Fullcrum today and all is fine. I have installed the kits correctly and there should be no problems. Just a bit strange fitting a washer on one bolt only,but they say that is what you do !!
Will put it back together tonite.
