Old 08-03-2009, 04:44 PM   #1
oysta
Escort MkII 1977 2.0L
Default To shim or not to shim??
Gday,
Rebuilding my mk2 front calipers. About to place my new pads in which are EBC greens. The greens came with some adhesive shims that you stick straight onto the back of the pad.
My question: Once the adhesive shims are on, do i still need to retain the original metal shims or are they not necessary? Perhaps they assist with applying uniform pressure to the pad. Thirty years has made the originals a bit distorted and the coating has mostly peeled off.
oysta is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 05:19 PM   #2
oysta
Here is a link to a photo. Old shims on bottom. New pad and adhesive shim on top. Cheers.
http://www.fordforums.com.au/photos/...hp?photo=53373
Old 10-03-2009, 06:12 PM   #3
F6 R-Spec
formerly PURSUIT-250
F6 R-Spec's Avatar
Use the 3m shims mate and throw the original metal ones under the bench, i had a set of red stuff on my P250, the packing box had been opened and there was no shims in there so i did not know that they existed.
The pad squeal was SHOCKING ( like a old Melbourne Tram ) with out the shims, long story short i complained and gave me a set of shims, fitted them and all fixed.
Cheers Mick.
F6 R-Spec is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2009, 08:33 PM   #4
oysta
Thanks Mick!
