Old 22-01-2009, 01:38 PM   #1
4dlvr
4dlvr
Default lr zetec head unit upgrade???
i want to change the head unit on the focus, i understand its a 1.5 din so my question is, is there any head units which are 1.5 din and fit straight in???
i cant be bothered with a single din and a spacer..
has any one done this???
also im assuming the swap over will be like every over would be like every other car??? eg pull out old one, wire new one, push in???
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2009, 01:53 PM   #2
BlackLS
yum
No the mounting on the standard unit will be different to aftermarket units.
2005 LS Focus LX
250,000kms.
Old 23-01-2009, 02:03 AM   #3
4dlvr
4dlvr
what do you mean mounting will be different???
i understand the sides are different and it may not slip in perfectly, but the aftermarket deck should have brackets to compensate..
96 EF FAIRMONT
215rwkw @7psi
Old 23-01-2009, 05:26 PM   #4
FOCUSonTHIS
FOCUSonTHIS's Avatar
I have not found a 1.5 DIN unit for the LR so I just kept the single DIN. I got a spacer from my Focus if you want to go that way in the end.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
