Old 21-01-2009, 07:44 PM   #1
finmac
Default Help with 84 Telstar
Hi guys,
Just a quick question, i have just bought an 84 telstar and there are a couple of things that need to be done.
Could anyone explain how to replace the idler bearing and the rocker cover gasket on an 84 Telstar? Bearing in mind that this will be the first time ive done this on any car..
Thanks
FM
finmac is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2009, 08:56 PM   #2
290v
290v
290v's Avatar
go to the Library they sometimes have the greogorys workshop manuals they could have a Telstar/Laser book for you to read better still ring them might save a trip
BA GT 2003 Silhouette
4 Speed Auto
290v is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2009, 11:30 PM   #3
dirty hands
Over Thinker
dirty hands's Avatar
rocker cover gasket .take off the air filter
pop off the plug leads undo the bolts holding on the rocker cover (there are 7)
lift off the cover
use permatex blue or black to seal the new gasket and prevent oil leakage
Idler pully
a guess because the repair manual is no a good guide!!! argh
undo/slacken off the drive belts -
the idler pully may have a through bolt or an adjuster set up
undo the bolt/ s holding the idler pully in place
spanners and sockets are metric 10 mm 12 mm 14 mm... should do the job ok
My car goes Brumm Brumm
Old 23-01-2009, 07:25 PM   #4
finmac
Thanks mate, ill give it a go tomorrow
Old 14-02-2009, 05:48 PM   #5
Sparty
Forget the permatex remark ... Gasket should be new and fitted DRY ... sealant applied onlt to the corners
Ask any tradesman the bad effects of putting silicone types sealants on neoprene gaskets
Sparty is offline   Reply With Quote Multi-Quote with this Post
