30-12-2008, 12:30 AM | #1 | ||
I went to a local Transmission place today to get a quote for 3.9's. Walking in with $1600 expecting it too be enough.... sigh. I was wrong.
I got a quote for $2000, to get 3.9:1 LSD.. Is there anyone that knows a better price?
Daily: AU Forte Wagon Project: AU Fairmont - Wants to be turbo The Family Car: 2009 G6E Turbo Future fun: 1968 Ford Galaxie 500 |
30-12-2008, 01:04 AM | #2 | |||
Critical Thinker
Still, I assume that is a complete diff with new bearings, rotors, axles and gears yes? Hmm it does seem a little steep.
30-12-2008, 01:32 AM | #3 | ||
Sounds about right for what I think he asked for.
You may be talking second hand/used. I think he is talking walk in walk out recond/rebuilt????
2015 FGX XR8 5.0 S/C 645 RWKW |
30-12-2008, 02:36 AM | #4 | ||
$650 to fit 2nd hand LSD and 2nd hand 3.7 gears in EF housing...
dismantle and machine LSD, cone clutch clearance, Machine & fit steel bushes. New diff bearings & pinion seal. machining to make the LSD tighter... drive car in and pick up 6 hours later customer supplied lsd and gears that was with these guys in melb http://www.mcnamaradiffs.com.au/home.html |
30-12-2008, 03:12 AM | #5 | ||
Critical Thinker
thats a dam good price. much better than 2k
30-12-2008, 07:59 AM | #6 | |||
30-12-2008, 08:53 AM | #7 | ||
Living the dream
2k seems about right, if a little on the high side. My mate had a new 3.7 LSD supplied & fitted to his VT for about $1800.
30-12-2008, 09:10 AM | #8 | ||
Boost Addict
new diff centres u can pick up between 500 to 600 inc carrier housing, then hunt around for ur own diff gears, if u dont mind second handies (as long as they look good) for under 300. carrier bearings and oil didnt cost me more than $50. because u would be using new gears and centre u would have to get the shimmed correctly (pinion gear to housing) and then both out shims for backlash.
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
30-12-2008, 11:04 AM | #9 | |||
Critical Thinker
30-12-2008, 11:13 AM | #10 | ||
Walking with God
Price is too high.
I had my diff rebuilt with 3:7s at the start of this year for $1,200. LSD would have added about $650 IIRC. I would have thought 2K tops. GK
30-12-2008, 05:27 PM | #11 | ||
www.TUFFCARPARTS.com
If they supplied NEW gears and a NEW LSD centre, then that price for a drive in drive out conversion is about right.
If anything is different to what I've described above, then it's too much IMO. Personally, I'd just grab a secondhand 3.45 LSD, and then change gears in that if need be.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
30-12-2008, 07:05 PM | #12 | ||
It would be a drive in drive out they supply everything.
I have considered buying a second hand lsd but cannot find one for a reasonable price. I may just have to suck it up and pay the 2000.. It will be all brand new with some form of warranty too.
30-12-2008, 07:14 PM | #13 | ||
Man for that price id rather go and get a Kaaz
30-12-2008, 07:21 PM | #14 | ||
MADED.6
yeah thats a bit much keep an eye out for some gears on ebay or on here and then get an lsd whole diff for like $600 and get it rebuilt with the gears fitted and should be about $650 to rebuild lsd and fit into housing just dont let them take 9it out of car its easy as and theyd charge probly 4 hours to remove and refit.
cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
30-12-2008, 07:25 PM | #15 | ||
New Kazz - $1600
3.9 gears $700 Bearings, oil and assembly $400 R&R diff cradle $400 Just a little more than $2000 but probably worth it I suppose?
30-12-2008, 11:15 PM | #16 | ||
seeing the prices and the qaulity difference Kaaz seams the better way to go, Yeah its about 1k more than the original quote for new gears but got damn it would last longer than a normal LSD specially the way i drive.
31-12-2008, 12:55 AM | #17 | ||
Kaaz would be sick, but I just can't comprehend 3k on a diff build for a moderately powered car!
But then I also wouldn't spend 2k on a standard LSD build seeing as the LSD would be screwed in no time anyway!
31-12-2008, 01:25 AM | #18 | ||
Kazz complete center 3.73:1 selling soon>>>>>>>>>>>>>>>>>>>>>>>
C
31-12-2008, 02:25 PM | #19 | ||
To start with you can't just bolt 3.9 gear set into a 3.45 centre. The pinion/centres run on a different offset so you have to first of all buy a 3.73 centre out of say a Skyline. Then you can put your 3.9s in. If anyone can do this conversion using good quality parts, rebuilt and guaranteed, for under $2000 they will get a lot of business. Dunno how long they will stay around though to honour their warranty?????
31-12-2008, 04:00 PM | #20 | ||
MADED.6
where did u get that info from mate i have 3.9's in my car and it has an ed centre in it.
u can buy the gears brand new from any diff place or even bursons or something could order them in. they are about $600-700 if i remember correctly my mate got it done in his ef which cost him $1200 to rebuild the lsd and fit and supply the gears. cheers josh.
31-12-2008, 05:28 PM | #21 | |||
AFF's 1st DM.......
$1800 for me 3.89, new cones/carrier, all new bearings n seals, and free drain/refill after 1000k's
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
01-01-2009, 03:19 PM | #22 | |||
How much would a brand new kaaz setup be? And would any tranmission place be able to order in their setup?
14-05-2009, 02:05 PM | #23 | ||
Well I ended up going the kaaz. So far it has given me a fair bit of trouble.. Though to be oil related but is coming back again..
I will be taking it back in 500km and getting the center pulled apart to make sure its not it.
14-05-2009, 05:09 PM | #24 | ||
not here much anymore
Why dont you actually go to someone who has a clue? Most places in Wagga know nothing about good performance orientated parts.
2024 F150 XLT
14-05-2009, 06:39 PM | #25 | ||
Just slidin'
I bought my diff off a guy on here, 3.9 LSD, just rebuilt, new cones and bearings. $450. Freight was around $130 as it was from Sydney. Labour to fit it was $200. They ended up pulling it all apart and putting it in my diff housing with new oil, checked everything to confirm it was new, made sure it was tight, $200. Cant complain about that. $780 for a 3.9 LSD.
This is from A1 differentials at Southport. Only thing is being old ricer gears, they are a little noisy at times, but with a 3 inch exhaust it doesnt worry me, lol. Its also pretty damn tight, and if your doing a real tight turn using even a touch of accelerator, the inside wheel will spin slightly.
MD Mondeo - For the family
14-05-2009, 10:34 PM | #26 | ||
about a fortnight ago there was a "COMPLETE IRS" with 29000 k`s on it out of an xr8 if i recall correctly, on ebay that went for wait for it................................................ .................................................. .....$175.00 you have to keep your eyes open, if it was`nt in brizzy i would have bought it for a spare.
15-05-2009, 01:13 AM | #27 | ||
watch this guy on ebay for lsd's he is a awesome bloke, all diffs have been reshimmed and stuff so yea not bad for the price, i got a lsd and 3.9s off him for $520 he bolted the diff gears on for me aswell and sent it in one package. It cost me another $90 for new bearings aswell.
http://myworld.ebay.com.au/nooksvill...:X:RTQ:AU:1181 |
16-05-2009, 09:44 AM | #28 | ||
I had 3.9's put in around a fortnight ago, cost me exactly $1560 drive in drive out. This included brand new gears, bearings and LSD cones. They even dropped me off at work and came and picked me up when it was finished.
FPV GS Ute #370/Brembo brakes |
