Old 18-08-2008, 06:06 PM   #1
AU XR6 UTE
Default How to change Globe in dash
Hey guys just wondering how you change the globe which lights up behind the kilometers display. I have a 2002 Au Series 3. It seems to be the right hand side that has blown so i am guessing there are two globes.
Any help would be great.
Cheers Darren
AU XR6 UTE is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 06:08 PM   #2
Falcon4L
'04 BA XT
Falcon4L's Avatar
they use light channels so it might only be one... either way you have to take the cluster out... the globes clip into the back of that..
1979 F350 Tow Truck
80 series Turbo Diesel Cruiser
Falcon4L is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 06:11 PM   #3
AU XR6 UTE
how hard is it to take the cluster out.
Old 18-08-2008, 06:14 PM   #4
Falcon4L
'04 BA XT
Falcon4L's Avatar
only ever done it on an EL and BA... I'm assuming its more like an EL... you have to take the surround out and you will see about 5 screws or so... undo these and it should pull out... even easier to do on a BA but I dont think the AU runs that set up... Basically you'll pull a few of the dash pieces off... not too hard just take your time.
1979 F350 Tow Truck
Old 18-08-2008, 06:15 PM   #5
AU XR6 UTE
and i should be able to get a replacment globe from repco etc.
Old 18-08-2008, 07:26 PM   #6
WoodysXR6
Wanting a sprint!
WoodysXR6's Avatar
Just 2 screws under the plastic plugs at the top of cluster and about 3 wiring harness to unclip easy as.
Just slide the cluster out after the screws are out nothing else is holding it in.
On track for mint turbo falcon
WoodysXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 11:43 PM   #7
UU TS50
T3 TS50 075
UU TS50's Avatar
just done mine last weekend part number is ER 10B765 D
cost of globes are about $5 each same globes do the clock aswell
get a large screwdriver in through the holes were the boot release button is and yuo may just need to prise the top edge of the crash pad up over the clips on the cluster
Cheers John
Cheers John
My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw
UU TS50 is offline   Reply With Quote Multi-Quote with this Post
